HEY GUYS JUST WONDERING IF ANYONE HAS HAD THIS SAME PROBLEM ON A HOT DAY AFTER TURNING THE CAR OFF AND COMING BACK TO IT AFTER ABOUT AN HOUR I DRIVE A COUPLE OF METRES AND THE A-LSD & 4WD LIGHT COME ON I SWITCH THE CAR OFF, RESTART AND USUALLY IT WONT COME BACK ON I THOUGHT MAYBE HEATSOAK OF THE OIL BECAUSE THE ONLY THING CONSISTANT IS THAT IT HAPPENS ON A HOT DAY ANY THOUGHTS WOULD BE GREATLY APPRECIATED
https://www.sau.com.au/forums/topic/150580-a-lsd-light-coming-on/
I have the similar kinfd of problem, sometimes "ABS" and "4WD" led comes on together, I turn the car off and start again, it disapear and comes back up after while again, some times it doesnt come back at all.
A-LSD, SLIP, ABS, and 4WD leds are ment to go away once you sart the car, if it reamians, thats mean you got prob.......sometimes i wonder if this a electrical problem.....hard to say.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
