maybe we should organise a r32 and r33 regency pack with std items like shocks, exhaust etc that we can have people use to get through, then all items are stored until someone else needs them?
Maybe like donate the items to be held at a single location, then lent out (with a deposit) as needed?
Obviously someone would have to keep the items to be given out, and organise it all...
how about we built a drift pig with all the left over parts :D:/
sitting in the shed R32GTR air box with high perf filter,dump pipes,intercooler and associated pipe work, standard ecu{chipped},exhaust pipe from dump pipes to cat and old brake rotor's fr and back and stock turbos. :D
have to say seen GTR32 for sale in paper un reg able for $12,500 0no {group buy track weapon} :(
Edited by savage GTR
Stock R32 GTST diff (manual)
4 x stock 32 rims with legal tread
Rubber intake pipework
Standard R32 GTST seats
6 standard RB20 injectors
what year is the car those seats are out of, i want to upgrade my crappy 89 seats for the newer ones if ur interested in selling them, or even if u need seats swap mine for urs + cash ur way.
R34 front/dump pipe
R34 lowered springs
R34 standard air box
R34 triple gauge cluster
R34 stock radiator
R34 stock trans cooler
R34 stock fuel pump
R34 stock fuel pressure regulator
S15 various stock intercooler pipes
S15 stock tail lights
S15 stock front/dump pipe
  • 1 month later...
  • 1 month later...
now all we need is someone with a spare rolling shell and we can make the SAU drift pig
Itll have no engine, but it'll run on hopes and dreams.
Edited by Pauly33GTS-t
all r33 gtst
stock exhaust and dumps,
stock interior,
stock airbox,
spare head rb25det series2
stock exhaust manifold x2
stock inlet, throttlebody,
4 stock wheels
stock intercooler,
stock rear wing
stock coils,
stock rear bar,
stock ecu
  • 4 months later...
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
