maybe we should organise a r32 and r33 regency pack with std items like shocks, exhaust etc that we can have people use to get through, then all items are stored until someone else needs them?
Maybe like donate the items to be held at a single location, then lent out (with a deposit) as needed?
Obviously someone would have to keep the items to be given out, and organise it all...
how about we built a drift pig with all the left over parts :D:/
sitting in the shed R32GTR air box with high perf filter,dump pipes,intercooler and associated pipe work, standard ecu{chipped},exhaust pipe from dump pipes to cat and old brake rotor's fr and back and stock turbos. :D
have to say seen GTR32 for sale in paper un reg able for $12,500 0no {group buy track weapon} :(
Edited by savage GTR
Stock R32 GTST diff (manual)
4 x stock 32 rims with legal tread
Rubber intake pipework
Standard R32 GTST seats
6 standard RB20 injectors
what year is the car those seats are out of, i want to upgrade my crappy 89 seats for the newer ones if ur interested in selling them, or even if u need seats swap mine for urs + cash ur way.
R34 front/dump pipe
R34 lowered springs
R34 standard air box
R34 triple gauge cluster
R34 stock radiator
R34 stock trans cooler
R34 stock fuel pump
R34 stock fuel pressure regulator
S15 various stock intercooler pipes
S15 stock tail lights
S15 stock front/dump pipe
  • 1 month later...
  • 1 month later...
now all we need is someone with a spare rolling shell and we can make the SAU drift pig
Itll have no engine, but it'll run on hopes and dreams.
Edited by Pauly33GTS-t
all r33 gtst
stock exhaust and dumps,
stock interior,
stock airbox,
spare head rb25det series2
stock exhaust manifold x2
stock inlet, throttlebody,
4 stock wheels
stock intercooler,
stock rear wing
stock coils,
stock rear bar,
stock ecu
  • 4 months later...
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
