maybe we should organise a r32 and r33 regency pack with std items like shocks, exhaust etc that we can have people use to get through, then all items are stored until someone else needs them?
Maybe like donate the items to be held at a single location, then lent out (with a deposit) as needed?
Obviously someone would have to keep the items to be given out, and organise it all...
how about we built a drift pig with all the left over parts :D:/
sitting in the shed R32GTR air box with high perf filter,dump pipes,intercooler and associated pipe work, standard ecu{chipped},exhaust pipe from dump pipes to cat and old brake rotor's fr and back and stock turbos. :D
have to say seen GTR32 for sale in paper un reg able for $12,500 0no {group buy track weapon} :(
Edited by savage GTR
Stock R32 GTST diff (manual)
4 x stock 32 rims with legal tread
Rubber intake pipework
Standard R32 GTST seats
6 standard RB20 injectors
what year is the car those seats are out of, i want to upgrade my crappy 89 seats for the newer ones if ur interested in selling them, or even if u need seats swap mine for urs + cash ur way.
R34 front/dump pipe
R34 lowered springs
R34 standard air box
R34 triple gauge cluster
R34 stock radiator
R34 stock trans cooler
R34 stock fuel pump
R34 stock fuel pressure regulator
S15 various stock intercooler pipes
S15 stock tail lights
S15 stock front/dump pipe
  • 1 month later...
  • 1 month later...
now all we need is someone with a spare rolling shell and we can make the SAU drift pig
Itll have no engine, but it'll run on hopes and dreams.
Edited by Pauly33GTS-t
all r33 gtst
stock exhaust and dumps,
stock interior,
stock airbox,
spare head rb25det series2
stock exhaust manifold x2
stock inlet, throttlebody,
4 stock wheels
stock intercooler,
stock rear wing
stock coils,
stock rear bar,
stock ecu
  • 4 months later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
