ok i got my ps test tomorrow at 11:45. Apparently it takes 2.5 hours to get there. BUT I HAVE NO f**kN CLUE ON HOW TO GET THERE. Checked melways in my edition (33-2006) it has nothing on it.
Street is 6-8 Handley Street Wangaratta. I live in vermont south, which is cloesedt to the monash freeway.
PLEASE HELP !! LIKE RIGHT NOW !! lol
thanks so much!!
(please dont ask why im doin it there, i can explain later, i just want to know how to get there.)
https://www.sau.com.au/forums/topic/150618-how-to-get-to-wangaratta-vicroads/
  • Replies 46
go up the hume... u can get to it off the ring road near epping way
ull go past a maccas n bp in one (there will b one directly across from it on the other side of the highway). there will b signs that say (wang exit 1km etc)
my bad. whereis.com.au
and of course it works for you n00b... coz your the one who did the search. you cant link it. it'll come up with a time out error
and from melbourne to wangarratta is straight up the hume.
ok thanks guys
so far ive got.
up monash freeway onto westgate road then to hume highway um that until wanagratta exit? sound about right? how long approxmiatly? not speeding lol
Edited by sillylankan
give urself 3 hrs from the time u leave (u will have plenty of time then)
use my instructions from when ur in wang.... when u get to the first set of lights turn right (its a weird t intersection thats actually angled)
yep sounds right. as soon as your on the hume its easy.
fair hike... 2 and a half hours or so sounds about right, possibly more
last time i went to wang, from here it took nearly 2 hours so i'd say more from where you are
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
