wonder if this is the Simon from performance forums many moons ago!
Hi mate!!
Unfort I cant d/l youtube vids *cries*
I beleive you would be right in assuming that yes.....
geez simon you go through cars like I go through undies.
why the constant change?
nice style, congrats. tried to get any sponsorship? I pulled all the QLD sponsorship for SAU together when we started, it was pretty easy with some salestalk.
haha yeah i guess ive had a few... had AE86's for 3 years... then i wanted something completly different so i got the cefiro. Needed rego and ceffy wasnt going to be easy to comply in SA so i got the 32 which is rego'ed.. Ive since set it up way better then ceffy was but it just needs some paint to make it look hot.
As for sponsorship.. i tried well over several hundred places last year to try and get some funds together to compete in DA, but i just didnt have any luck.. secured a couple of smaller sponsors and every little bit helps but still at the end of the day it just isnt enough.
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
