Hey all, I just ordered these ($270, still need to be told delivery cost):
http://www.perfectrun.com.au/performance%2...ppbrakeline.htm
Are APP any good? I was contemplating the Endless ones, but for $350ish plus delivery I went with the APP brand. I might get the clutch line as well when I get the funds for the clutch itself as well....
There was 2 group buys but I decided against them (although 1 ended in August):
http://www.skylinesaustralia.com/forums/in...howtopic=127127 - $309
http://www.skylinesaustralia.com/forums/in...howtopic=128648 - $360
https://www.sau.com.au/forums/topic/150627-braided-lines/
I use the nismo lines on my GTR and they are very high quality. If anything though the APP ones are just as good or better. They are not specifically ADR approved, but I would suggest their design and manufacture do meet ADRs, they just have never sought or gained 'approval' (if in fact such a thing exists).
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2805595
I thought www.braidedlines.com.au had the strangle-hold on ADR approved lines?!?!
Just a vague memory.
The difference between an ADR approved braided line and not is a little rubber sleeve that goes inbetween the hose and the connector when its crushed. It'll have a compliance number on it... That's the only difference, line and fittings are exactly the same!
Any of your local ABS service centres can make ADR approved lines! :cool:
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816909
jetpilot1986
Thats not correct because the goodridge hoses are ADR approved and they don't have the rubber sleeve
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816931
I quickly searched for tutorials but theres none on changing brake lines. Is it easy or hard to do? I have to replace my front wheel barrings soon so I can do both.
Tom they are not hard to do. The hardest part of the process is getting hold of a brake bleeder etc to do the job.....bit messy too :cool:
What Mr keets says it correct...tech they make your car illegal and unroadworthy but I am yet to hear of a claim or otherwise (roadworthy etc) being knocked back because of them.
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816940
Tom they are not hard to do. The hardest part of the process is getting hold of a brake bleeder etc to do the job.....bit messy too :O
I really do need to bleed the brakes again I think (or get a new brake booster). I can hold my foot at a certain point in the brake and I get a constant squealing sound :P
Do Nissan sell the brake bleeders or are they a supercheap item?
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817300
Are you sure the squealing isn't coming from the actual brake pads/rotors? It is a common thing on skylines and I'm sure a search here would bring a heap of threads about it. Does the pedal feel soft...ie you brake at a point and to maintain the same braking force the brake pedal drops more?
Brake bleeders are basically a hand pump (although you can get elec ones)....you disconnect the brake line at the caliper, attach the bleeder to the system and pump the fluid out. You also use it once you are finished to get all the air out the system. Most tool places have them....
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817325
No, its defaintely a booster or master cylinder seal because if I get it in the right spot it just keeps on and on squealing ..... ( :P ). It happens everytime I stop. Pedal is soft also but thats what ABS does anyway isn't it?!
I bled the brakes through the ABS bleed holes last time so maybe that was the problem.....
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817594
  • 1 year later...
hi guys im currently in the middle of a brake upgrade on my r33 gtst, im going to run rda slotted rotors on all 4 corners as with QFM pads, whilst i was swapping out the front rotors today i notice that on one side the hard line that runs into the caliper from the bracket where the hard line turns to a rubber line is broken.
can u get these from any decent brake store or do they need to come from nissan?, i wouldnt mind upgrading to braided lines but does this replace the hard lines alltogether by just running straight to the caliper?
all help much apprietiated
cheers nick
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-4130814
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
