Simply get more power to get better times
It really depends on how much money you have to spend
First probably get a full exhaust, then air filter, then cooler and up the boost.
After doing those standard mods you can do bigger things like change the turbo
Also because you have a gtst it'll be hard to beat a wrx off the lights because they are AWD. You will catch up to them once you get traction after some simple mods
Originally posted by playa
yea i got exhaust air filter intercooler, so next step get....
* Exhaust Cam Gear ($250)
* Boost to 10-12psi ($200)
* PowerFC ($2000)
* Good quality tyres ($1100)
* Pineapples ($150)
Forget the bigger turbo, the extra power you make out of it will be lost in hitting boost and putting the power to the ground. You want a constant steady power curve to give you instant power and the stock turbo will deliver more than enuff power for this.
If your -really- after a 'bigger' turbo just get the stock turbo hiflowed, once again it will deliver more than enuff power and will boost up similar to the stock turbo.
Now how many people spend heaps of money on their engine but forget that somehow they actually have to put all that power to the ground? Do yourself a favour and buy a set of good quality tyres (back atleast).
Pineapples will give the rear end better squat and will force the car into launching harder in a straight line which is exactly what you need.
Note: The only experience I have is reading forums, not putting theory into practice. But thats only until I get a good set of tyres.
okay, nice wide wheels at the rear will help.. trust em i know.. i have shit tires and it sucks getting off the line. Even with minor mods and only 10psi i can boot it any surface or i get wheel spin :)
My car also has a different diff, which gives more accel, less top speed - to changing your diff to a higher ratio should also help. I think a std is a 4.11, so a 4.5 or more could be good. Only thing it will put your highway revs up a bit - mine revs at 3100rpm at 100km in 5th, compared to 2700 rpm std.
After exhaust and more boost, I'd look at getting the power to the ground.
Good tyres
Good alignment
Clutch/flywheel
Suspension setup for drags (pineapples etc)
Mechanical diif (2 way etc)
And as dAVE said, higher final ratio.
And lot's and lot's of practice.....
You may not need to do all these things to beat a WRX, but hay, why not :)
J
All you really need is some aftermarket management I reckon. A Super AFC or preferably a Power FC should give you that bit extra to get ahead in the 0-100. Just practice your launches. It's easier to launch a Skyline than a WRX (assuming they aren't doing a clutch dump - and if I owned a rex, I'd be taking care of my gearbox) as you can get some wheelspin to stop bogging off the line, and they can't.
You just need to get off the line better...
Pineapples...
Adjustable rear upper arms...
maybe bigger rubber rear but you could just try really good rubber first...
good clutch...lighten the flywheel while your changing it...
Maybe a mechanical diff if you're really serious or lock it if your too serious.
You may need more power but even iof you do later, you will still need these mods to get the power down effectively, they are cheap (relativly to some of the engine mods suggested above) and will get you off the line like a rocket...
I think you would be surprised at the difference this would make.
cheers
russ
If you have enough power is it actually better to have longer gears so you dont waste time changing gears....ie you have enough power to spin the wheels way too much all through second and into third anyway...
If you had a very low ratio diff like a 5.1 it would technically accelerate faster in gear but you might have to be in third to get to 100km/h...wasting time changing gears and much wheel spin...if you had a 3.9 or a 3.7 you might just make it to 100km/h in first??
You have to have enough power though...
Not too sure
Russ
Get a set of wide normal profile soft sidewalled tyres.
I.e Simex in a 225 50' 16" grip on my car very well. I can launch with them up around the 4500rpm mark with bugger all wheel spin. Simex are cheap, not rotational and spin like hell in the wet, a very dangerous tyre in the wet. I almost lost it by ever so slightly coming on to high boost in third gear at a low rev.
For a decent amount of sidewall flex, so that the tyres is flattened out on to the road when you launch you need at least a width of 4 fingers. Side wall width that is. :)
It is pretty difficult to beat a WRX off the line.. Even GTR's have trouble.. WRX's are full time 4wd that is why they break so many gearboxes.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
