  • Replies 56
"whats a matter alex, them damn gtr's holding the track beast up again?"
Sorry, I dont get that comment? Track beast? A 1800kg wagon? Sorry but I doubt it. Its rather just something a little different. Its for sale anyway now, moving onto something much more fun than i'd say any GTR would be, you just gotta be into them.
Ok, you didnt mention any names, but implications are enough.
Imagine being in a hall full of black people, and yelling "WHITE PEOPLE ARE THE BEST", that would imply that you think lower of black people as they are not equal.
It doesnt matter if you didnt imply it either, if people interperate it as an implication, thats enough to make it one, which clearly the very first poster did.
So I shouldn't post anything just in case someone THINKS i'm implying something......? :)
You came in and named a name, and the forum it came from. end of story :laugh:
my left mirror doesn't fold in anymore :(
must have a look at it closely one day...
but mine are wired to my remote, so when i arm the car.... BAM!! fold in mirrors! that's chuck norris cool...
my left mirror doesn't fold in anymore :D
same here... mine stopped working on the left too :( conspiracy! Chuck Norris must've roundhoused it while I wasn't looking.
it still "whirrs.." as if it's turning in, but stops after about half a second. are these things easily pull-apart-able?
chuck norris spits on electric fold in mirrors. He has steel side mirrors, which he just bends in with his bare hands when he parks, and then bends them out when needed, before taking off in his vehicle. same with his rear view mirror, solid steel.
ONLY chuck norris can adjust his cars viewing aids, a lesser man would just break his arms trying...
michael richards tried that...and failed miserably....ah, who could forget those words that changed everyones view on Cosmo Kramer :(
Edited by emsta2003
you lie. Chuck Norris does not need viewing aids nor a transportation method. People simply wait till Chuck Norris gets there on his feet of great testicular fortitude.
Mine does that as well. I think there's a time delay relay of some sort that stops it from trying to keep folding. Something must be jammed in my motor or something.
You lie. Chuck Norris makes the destinations come to him, including continents :)
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
