i know this is silly, but i took the vacume off the bov, so it wouldn't open, and i got teh flutter sound, but the car was soooo lagy and didn't want to boost past 5psi, the dam thing sucked. Is that what normally happens when you block on teh BOV.
mind you i have connected it back up, it was just being silly.???
My understanding on how a BOV works, is that the pressure helps holds the BOV shut. Hense, when there is no pressure working on the BOV at all, it is like you are introducing a big leak.
  • Replies 70
.............. is there any hope for these people.
can just see this scenerio
import car sales man: " i just need you to listen to this recording before you qualify to own a skyline".
tape recording can be heard........ vuuuuuuuuu tu tu tu tu tu
customer: "wow bru's da iz da shickest sound dis side of chapz ay....."
car sales man: "get out of my shop........"
ohh i see so if i just take of the hose to it, then the car will leak boost as the BOV has no way of being held shut, makes sence, learn something new everytime.
My question is, there are so many cars running arround with an BOV but still have flutter, can this be from an external gate, or the BOV being set to tight?
I have read many posts about the flutter, and was wondering, on the weekend was washing Jumbarie 16 and many of their drag cars had flutter, i presume that flutter was bad, but many people have that flutter sound.
Thats right, you need to pipe connected no matter what or you'll have a mad leak.
The way people block the stock BOV is putting a metal gasket between the return pipe and the BOV, that way the air gets trapped and has nowhere to go but back through the turbo (not good according to lots) and out the air filter.
can be certain that it wasnt the wastegate making that sound....
as for the cars at jambo making that noise..... big compressor + heavy spring on bov = some reversion
as for your normal run of the mill cars that still have a lil bit of reversion, as you said, bov is possible too tight
Edited by drag-on silvia
dose /doʊs/ Pronunciation Key - Show Spelled Pronunciation[dohs] Pronunciation Key - Show IPA Pronunciation noun, verb, dosed, dos·ing.
–noun
1. a quantity of medicine prescribed to be taken at one time.
2. a substance, situation, or quantity of anything analogous to medicine, esp. of something disagreeable: Failing the exam was a hard dose to swallow.
3. an amount of sugar added in the production of champagne.
4. Physics.
a. Also called absorbed dose. the quantity of ionizing radiation absorbed by a unit mass of matter, esp. living tissue: measured in gray or rad.
b. exposure dose.
5. Slang. a case of gonorrhea or syphilis.
–verb (used with object)
6. to administer in or apportion for doses.
7. to give a dose of medicine to.
8. to add sugar to (champagne) during production.
–verb (used without object)
9. to take a dose of medicine.
[Origin: 1590–1600; earlier dos < LL dosis < Gk dósis a giving]
—Related forms
doser, noun.
pidgeon pipe, just gay.
This guy can relate to "Failing the exam was a hard dose to swallow"
and maybe hes got "the dose" haha refer to "5."
Edited by Pauly33GTS-t
If you unplug the vacuum hose (and not plug up the hose) it wont really work because the standard bov's leak, they have a small hole in em underneath therefore introducing a vac leak so you'd really need to block it either with a plate in between the bov and the pipe its screwed onto or put something in between the hose connected to the bov and the return pipe going to the intake pipe. That works well with no leaks but if you don't have it tuned to compensate for the added fuel it throws in the car will start backfiring on ya cos of the AFM. Thats the only thing i don't like about AFM cars... its the shit you get when messing with vented/ blocked bov's.
I reckon 5 mates packed in the back yelling and screaming and throwing half full cans of beer randomly at cars, bikes , pedestrians and small dogs is a far better way of drawing attention to yourself.
Although if you already have that option get a few off duty barmy army members (they don't have much work on right now) to sing a loud and catchy song about how your mates car goes 'dose' from the back seat of the car, even from inside the boot?
gees, I have absolutely no clue what wastegate flutter is supposed to sound like.....all I know is that people with external wastegate goes like.........vrrrooooooooommmmmm WAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!
so could someone clue me in as in what the flutter is supposed to sound like?.....all the flutters I've heard is from fully sik bro's and their blocked off bov
mythbusters ahoy >_<
#1 there is no such thing as wastegate flutter
#2 flutter or chop chop (vl style tutututututu) is air pressure collisions in the pipework, as a result of compressor surge, as a result of running no bov
#3 a wastegate making a "vrrrooooooooommmmmm WAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHH" noise is a sreamer pipe setup, nothing to do with compressor surge, bovs, flutter etc.
#4 compressor surge occurs when pressure past the compressor wheel exceeds what the map dictates, so if you goes beyond that, the wheel surges violently
#5 when you block the bov, on gearchange the pressure collision causes the compressor wheel to surge, as we know #4 happens when pressure past the wheel goes beyond what the wheel can supply, so by blocking the bov, you induce compressor surge
Yep gotta agree there, to scare ppl....hmm 38mm external gate with a 10" pipe comming off it.....
vrrrooooooooommmmmm WAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!! ppl running holding there ears....nothing like it
to be honest I find it pretty gay........not as gay as vl with their tutus........not my cup of tea
LOLL Its true its just for attention.... no better way to get noticed than dirving around with a tutututut noise comin from your car...
Guest
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
