Anyway, I had a 369rwkw RB25 setup for 18months.
I also had the whiz bang Walbro (definately not a copy), it was wired correctly.
It was maxed out by 250rwkw/16psi.
Swapped for a Bosch, and AFR's went from 14's down into the 10s with just a fuel pump change and nothing else, running the factory rail presure.
So, there is experience behind my posts, i also know of others that have had similar issues.
Seems someone people do, some people dont.
Don't doubt what you're saying at all mate, although I am surprised that it maxed out at 250rwkw.
I've got a consistent AFR of 12, running 285rwkw @ 17psi - so I guess this just illustrates the fact that there's plenty of conflicting experiences/advice with this pump.
Interestingly enough, there's a small write up on fuel pumps in the latest issue of Zoom - from what I remember, Mr Donnon was even implying that these pumps are good for 350rwkw (take that one with a grain of salt), so buggered if I know... :wub:
Anyway, I'm digressing off the topic...
My 200rwkw definately cost more than $4k...
FMIC - $1500
Exhaust - $1000
Clutch - $1000
PFC - $1100
EBC - $500
Tuning - $500
  • Replies 48
Well ok so i'll put a pickle in the mix.
I got all the parts myself and did the installs myself so here it goes.
Walbow Gss342 pump $195 (genuine pump too, not a coppy)
FMIC $399 Just Jap one (fitted well no modifications can't complain)
HKS Pod allready in the car, i made a CAI for it
Clutch Excedy HD $389 from Slide (mine died)
Splitfires, had to get my coils DIED big time $589 from Slide
SAFC II $399 new from Ebay
GIZZMO EBC $369 form Abarn
Exhaust was $199 for full dump, free HIGH flow cat, $160 to get the rest made up, and the muffler was free.
Full Tune spent six hours on it $200
Result was 187rwKw at 10.2psi, some more tuning and managed to get 201rwKws at 12.3psi.
BUT my midrange is down due to not having a PFC.
so if i didn't have to get coils and clutch, i think a 2K budget i guess the results are all good.
this is my 208rwkw costs
walbro intank pump $160
intercooler kit thru gktech $400
3" dumpipe $200
3" exhaust gutted cat $350
boost set to 12psi..
stock ecu..
i done it under $1500 + $200 labour to make exhaust and fit cooler kit..so $1200 all up
since fitted powerfc/stage3 highflow from sliding..waiting on z32 afm and fuel reg then maybe a tune?mmm
Edited by l0WRB
hmmmmm
250rwkw is quite fast for the street. Currently I'm running about 250 and its damn fast, 1bar @ 3k - pulls all the way to the line.. I can keep up with the best of them when i get traction.
So what did I add to the above to get it there?
New turbo..custom...think of it as a highflow.
FMIC
Dump
New 730CFM Hi-Flow Cat
New zorst to the tips
AFM
PFC
AVCR
Spitfirepacks (cos my old ones were dead) new IX plugs cos i had them
@1bar was running 250rwkw. Shitloads more everything, everywhere.
What happened soon after?
Clutch...fried
Stock Suspension...couldn't hold it down
Tyres/Wheels...not enough traction
WHats happened next?
Wheels : Work XT7s from J land. 18x9.5 on the rear fitted with 265s $4k all up
Bilstien Shockers + Whiteline springs (like the SK Group Guy) - Setup by Centreline in melbourne. $3k all up inclufind some other bits and pieces.
Twin PLate Push Button Clutch - cos I wanted grip but always wanted it to be as easy to drive as possible ~$2500 fitted with some other stuff.
Whats happeing now...
Running on the turbos max eff. of 1.3 bar. WIll run to about 290 I rekcon based on a run we did before the clutch was slipping on the initial tune with the new turbo...but in the end my aim was street speed...not max power so even if its 270 I'm not fussed. gets to 1.3 at about 3k like a stock turbo...lol lets just say it goes off the line..IMO max power is a bit of a wank factor to you mates and keybaord warriers when we talk about street driven cars, its all about response, quick spool and fast 0-100 for me...that was my aim.
Overall, spent some money. This is with stock internals for the moment...wait until they need a replacement!
IMO...u can get to 250 probably...but what R31Nismoid was saying...its more than just peak power, its response and the ability to drive the thing witht he power u have got.
3" dumpipe $200
stock ecu..
RRP please
So 210rwkw without even an AFC?
Got a timeslip with near on 108-110mph? Cause i think 210 without any interceptor at all is getting into the ridiculous.
I ran 111 with 220rwkw :worship:
im with nismoid on this one. All the reading ive been doing and my own experiences with my car lead me to believe that hitting 200 with a complete stock ECU with no piggy back is near impossible. r'n'r will snap you as soon as you try and get the boost up to the pressure required to pull 200 kw. im actually gonna decrease the boost a bit from mine (its at 12ish atm on stock ECU) to try and avoid a really nasty flat spot in at around 4k revs as i think it will give a better speed. like someone said, the KW figure is a rough guideline at best. If your engine is cutting out from excessive boost at 4k revs, you wont be winning any 1/4 mile races.
ive got:
custom stainless steel dump pipe
highflow stainless steel cat
Nismo FMIC
CAI + K&N pod filter
500hp fuel pump
bleed valve set to ~12 PSI on high.
and i get about 185 KW
Edited by Strik3r
RRP please
I ran 111 with 220rwkw :)
well it was done in shootout mode so im guessing it would read higher? I wish i could take the car to a test and tune see my mph..but unfortunately banaraby got burnt down not long ago..once there back up and running id love to go and check out the mph mmm once tuned id only really want 220rwkw anyways..genuinely hehe...last time i went to a test n tune was wit my calais turbo..160rwkw and got 100mph..so yeh 220rwkw once tuned should see over 110mph im hopin!
Edited by l0WRB
I got 200rwkw and a few 106mph passes, and I did it rather cheaply!
$350 for ECU remap
$450 for Split Dump/front pipe
$400 for Stainless cat
$800 for Catback
$1500 for Clutch
$500 for Intercooler
$250 for Bosch 044 pump
$4250 + labour.
So I guess I do agree! If I went with an aftermarket ecu and a tune add ~$1200 to that figure.
You can argue that you don't need the intercooler or the clutch, but to each their own.
None of this is including any suspension work either...
The $2500 mentioned was actually $2400 includes piggyback & intercooler the clutch was done before the mods so forget to mention, but add that anyway $440=$2840 thats a far cry from 4250+$1200 to get the same result. I used an AFC and your $1200 is APFC im assuming, so take $600 of that still takes you close to 5k, $4250 plus labour that would put you in the $6000+ without the ecu, and chasing $8000 if not over with.Well i dont think i need to do the math any further.
Do you need a mechanic ???:whistling:???
Edited by Spoolemup
Well... stock ECU, i call a "happy" dyno. I'd like to see some ET's to backup that 200rwkw without any ECU/interceptor as they'd be amusing without a doubt
I dont doubt that you have the experience, But your telling me how much i cant do it for & im telling you how much i have done it for, atleast when it gets to 200kw. Im yet to decide on a turbo upgrade on this project but im guessing a Garret would be better than a GCG both in price & performance?. Are the GCG's your mentioning Highflowed stock turbos??? There are others who agree with you on the price/performance issue, Lets just say Hidden Agenda Anyone? :whistling:
hmmmmm
FMIC
Dump
AFM
PFC
AVCR
Clutch...fried
I understand the drivability & the wank factor all too well? Some wank to HP figures others wank with their wallets and others wank the wankas to wank their wallets and theirs a good chance i use the term "WHAT A F#$kN WANK" more than you :whistling:
Hahah, no mechanic needed :thumbsup:
Of course it could be done cheaper than I did it, and I even purchased some items second hand/discounted...
Substitute my;
Split Dump/Stainless Cat/Jap Brand Cat Back for a $700 mild steel x-force
Nismo twin-plate and flywheel for a $450 item
Jap Brand Intercooler kit for a $385 Chinese copy
and that would've brought me down to 2k flat, whether or not I would've ended up with the same power figures, driveability and linear power delivery I couldn't tell you.
whats r u saying? its all a wank? not sure how that helps him choose parts. Although wanking would make him feel better no doubt.
I dont doubt that you have the experience, But your telling me how much i cant do it for & im telling you how much i have done it for, atleast when it gets to 200kw. Im yet to decide on a turbo upgrade on this project but im guessing a Garret would be better than a GCG both in price & performance?. Are the GCG's your mentioning Highflowed stock turbos??? There are others who agree with you on the price/performance issue, Lets just say Hidden Agenda Anyone? :huh:
Depends what Garrett vs what GCG offering really.
You can search and find a lot of information about them, and Slide's turbos, and many other suppliers.
And to imply hidden agenda, grow up
And thats probably the post of the day, couldnt agree more! :)
As its likely that you would not have, i think you know that aswell
Ok so some people seem to be getting some power out of the Walbro. The only valid conclusion in this regard then is that you can't reliably expect one to do it for you if you buy it now.
I pulled the return line off my fuel rail when the car was on the dyno and at about 240rwkw the return flow had completely stopped. The AFR's had started to lean a little and we stopped the run so we didn't blow the engine.
I replaced the pump straight away.
So maybe you will get lucky, maybe not. Don't let us stop you taking a punt, just be careful.
Monsta turbos = you take your own risk.
You will get to around 250-260rwkw, which isnt 300rwkw... but the 250rwkw is amazingly responsive. Virtually like a stock turbo with a truck load more ooomph everywhere, and will make a truly fast street car.
Clutch - see the Drivetrain section. There is a sticky thread about good clutch makers :)
I spent so far: series 2 r33 GTST:
$580 = $980 installed - KGCM intercooler
$70 - Turbosmart vee port bov, 2nd hand off my mate
$550 = $620 installed - Eboost 1
$550 - 3" Dump pipe and high flow cat (already had cat back)
$980 - Apexi power FC with hand controller (from japan... cheaper, just that instruction manual is in japanese)
$125 - Custom cold in intake and Simoto pod filter and heat shield.
= $3325
As for the quote, R31Nismoid, u sure know what your talkin about so i'll listen. U reckon a 250rwkw car would be faster on the street than a 300rwkw one? i got 18 x 9.5 tyres on the rear now and with roughly 200rwkw "differance in dynos" its ok with traction compared to the stock 16 x 6.5.
What do u reckon the next step is, im thinking definatly fuel pump, injectors since mine are maxed out now top mount exhaust manifold and a bigger turbo, but im not sure what size... sorta depends what u say bout "250rwkw vs 300rwkw"
A well sorted car (Good suspension setup correctly, good tyres, diff, lighter flywheel etc etc) with 250rwkw will destroy a car with 300rwkw and a poor setup like stocker suspension, average tyres as you will never ever put that power to ground.
There is a lot more to a fast car than power, in fact, it has only a small portion to do with power. The main portion is every other little part.
GCG hi-flow IMO is the way to go hands down having been in a number of RB25's with GCG's, great response and midrange = fast street car. 250rwkw, stock manifold etc. Bolts on. Cant ask for more. There are other hi-flows on the market, but i have not personally seen the results, so i cant comment as accurately
If i had an RB25 again, that would be my choice for a street car.
As an example of what nimoid is saying when i worked at chiptorque, we built a s14 which made 376rwkw, big turbo, cams, 26psi, on the street, it felt like a diesel gemini until 5500rpm, almost impossible to make boost in first without being silly. If it ever came on boost on the street, it would wheelspin 1,2,3,4 in about 100m, it was the most impracticle car ever, no good for anything. No average power, the further you can stay away from something like this, the better.
Alright.. Thanks heaps guys
One more thing is the GCG hi-flo a top or bottom mount turbo, and where do i get one, their bout $1750 hey? I got told to look at a GT30 or GT35?
Are u sayin keep the intake or exhaust manifold stock?
And what about the longer intercooler pipes "as attached" with that kind of power "hence i was thinkin intake manifold" ?
What boost would that be running to get 250rwkw?
Cause i heard if i go above 14 i should really look at changing the intake manifold and in turn shortening and enlarging the intercooler piping say to 3"
The intercooler piping even heats up now so im thinkin that with more boost cooler air will help heaps?
Or should i keep it all the same and get the stock intake manifold polished to suit the rest :)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
