Okay so this is probably a pretty common topic but I'm at a loss for where to go next with my mods so I'll start with the current list:
S1 R33 GTST
TD06 turbo
3inch turbo back
FMIC
Profec EBC
SSQ BOV
Turbo timer
Tien/Bilstein springs/shocks
OS Giken twin plate
I was thinking my next step should obviously be ECU upgrade then I thought I could probably use a box for my pod filter and some cold air but then I got to thinking that fuel upgrades might be more important first. I'm not really bothered (don't care) about asthetics at this stage and this is my first serious performance car so I don't want to pour a huge ammount of money into something I'll probably sell in a year or two.
Between now and the next big step I have a few small things planned like a catch can and HICAS lock bar, possibly an oil cooler too.
So basically my question is what's the most important thing for me to get into next? The car is just a street car and I'm only chasing a reliable 300-350hp atw but I'm hoping to see some track time and I do go to the drags a bit.
https://www.sau.com.au/forums/topic/150720-what-next/
With that set up and ECU should get you in the mid 300's. Just be careful as stock internals don't take much more than that for too long, 350 as you say is good and safe. Also your gearbox would be the next weak link. They would be next major mods. Small mods would be as you say, cold air intake, catch can etc. With the upgrade of ECU you can then upgrade injectors etc too.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2805167
He clearly needs neons and a huge drift wing :nyaanyaa:
I'd be doing injectors, ECU and fuel pump all at the same time and getting a final tune.
You can't up the boost without more fuel, the standard ECU won't support larger injectors, and the fuel pump won't flow enough for the added power. Pretty big outlay but you'll finally get to crank the TD06 up to max.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2807589
hold your foot flat and see what goes first, pistons or rods, we can all place bets.. im sure there is alot of guys with alot less then 350 who's engines have gone bang, guess it depends how u drive and whos going to build it as to how long your rebuild will last, and also how heavy your wallet is....
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2808257
The rods seem to be the most common weak point much over 350. Drive quiet and it will be fine over that but what is the point in that?
ECU, some will recommend PFC, if you wanna ditch the AFM etc go for a Wolf 3D.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2808898
S1 R33 GTST
TD06 turbo
3inch turbo back
FMIC
Profec EBC
SSQ BOV
Turbo timer
OS Giken twin plate
what type of td06 are you using? (td06-20g or td06-25g and what size rear housing 8,10 or 12cm?)
I would go with the following mods:
ECU (Apexi PFC - you should be able to find a second hand one very easy, as they no longer make them)
Fuel Pump (tomie,nismo etc etc, they are all bolton and will supply you with enough fuel)
Injectors (NISMO 550cc or 740cc; because you have an rb25 get nismo as they are direct bolton, unlike sard injectors)
AFM (z23 afm + z23 afm plug)
go get a tune and depending what type of td06 you have you should be in the 300rwhp range.
Reliable depends on your tune, im running 337rwhp @ 16psi with 11:1 AFR (rich tune) (100,000km) my car see alot of limiter smashing and bashing, abuses from antilag and i do like to do abit of track work (drag,mc and drift when i can get time) AND i havn't had a problem yet
(my engine is unopen stock rb25det)
good luck
oh and if you need some help finding a second hand pfc, i can source you one
-Michael
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2820316
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
