YEAH we made it through the prolouge, span out bigtime, cost us about 23 seconds, so if we didn't spin, we would have been about mid to top of feild. ATM we are LAST, so we start first today. DID some suspention work, to help the car turn in more, se how that goes.
  • Replies 380
Yeah sorted, thanks...jb33 came to our rescue.
We made it through our first targa day in 1 piece, w00t! Car was very taily especially in the wet with all the tight corners, it is much tailier than it is on a racetrack. Great fun though, should be some good pics :)
But we still have a missfire that is shitting me, changed the plugs and ignitors (did the coils and afms yesterday), hopefully it is sorted now.
yeah I just got the call a few mins ago, but didn't want to post anything. thought I would leave it up to duncan, but it's out there anyway I guess.
sad news indeed. but very pleased they are both ok, so they can come back and tell us all about it over a beer. :D
Not sure what happend, i'm just managing the team and built the car, as i was unable to drive or navigate due to personal issues (WIFE)
So Today i had to be in hobart, recived a text 10 minuts after it happend, got on the UHF to the CROW, the stage official, and no good, can't get trough, phones off, service crew is there, waiting for a report back.
JAS-25T here posting for Team Raceworx including Neil
We will be getting the car back out tomorrow - already sourced parts and a champion of a bloke that is lending us his garage to work on.
We didnt come all this way to retire already.
if it takes all night to fix - so be it.
:P
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
