  • Replies 40
Before yor freak out too much - put it into context.
How mch does the average (say used $20k) Falcadore devalue per year? Maybe $2k? The imported SKyline is unlikely to be much worse.
Also - if you are anything like me, the cost of mods over your few years of ownership will probably far outweigh the cost of devaluation.
Bottom line, if owning and driving a Skyline makes you happy - keep it.
If you are going hungry and/or are about to be divorced, kicked out of the folks house, locked up for not paying speeding fines etc - then sell it.
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-309719
Well that's what I thought would happen! But it seems not so far! Someone said that the GTRs in Japan were going to be giong up in price because they knew about the Aussie 15 year thing :confused:
Ahhhh well stuff it I like my car I'm gonna keep it :P
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310143
I wouldnt worry dude. As I said in another thread the whole 15 year thing is going to be changed to 20 years to prevent all the good stuff coming in. The quality of the '89 stuff will be pretty low, I mean how good is a GT-R going to be after 15 years of caning?
Jash
PS I waved to you yesterday
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310749
R31 GTS imports are not a lot cheaper than R33 GTSs ($15000 v $20000) so don't panic. HSV cars drop in value the price of a R33 GTSin about 3 years so spot the Dick heads.
A mate wanted a Jash GTR a while ago and needed to sell his
HSV to buy it the car is better than new condition and Colin
could not get 1/2 new price so a 20grand R33 GTS could be
burnt in 3 years and still not loose as much as a Heavy Slow Vehical
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310761
yeah but steve the GTS R31s are relatively rare and are collectibles, whereas the 32 GTRs are still fairly prolific.
one of the biggest differences in the prices is related to the difference in the processes required for import.
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310790
Jash
So do you think they will change it to 20 years?
The people who buy cars now will be pretty pissed!
PS I waved back but couldn't get my hand up through the gap in the window quick enough and you had turned your head back :P
PPS I like that Stagea! :P :burnout:
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310995
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
