  • Replies 64
Posted Images
Hey all, im back from my holidays.
Yudy you know i live and work not far from racepace so i will come down ONCE ITS ALL DONE AND OUT OF THE WORKSHOP hehehe.
Pm me for my mobile number, then you can just give me a quick call when its nearly done and ill pop around.
Simon
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2809493
Simon
not a problem will do.
Hei Ska is my typing that bad>! LOL
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2809900
hei guys ,
alex and other people who wants to meet up this afternoon please PM me your mobile details to me please ? so that i can call you guys later on. Thanks
hey guys i have just moved to meblorune how many stagea's are going to be there today would be good to meet u guys
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2816463
so, how did the tune go?
there was a bit of hick up during the tune but this is laargely due to the cam gears i supplied ben with. Its all good now should get the car back about after lunch. Will keep you guys updated once i get the car.
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2826102
well i got the car back.
First impression it sounds normal and stuff but when you drive it its a whole different car.
Throttle response is much quicker and crispier. Turbos spool faster. Torque is crazy planted my ass onto the seat when you step on the gas pedal. I like it :sorcerer: . BTW Mods i did to the car Power Fc, original boost controller, Cam gears, Drop in panel replacement filter and a full 3" exjaust system with a high flow cat.
Bottomline it maxed out at 236.5kw@4wheels.
Will post the dyno result tommorow.
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827627
Bottomline it maxed out at 236.5kw@wheels.
Holy Snapping Duckshit Batman!!!
You would have to be happy with a result like that. I don't suppose there would be any chance of a peek at the dyno sheet? Kinda interested in the torque curve from a result that good.
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827740
Here it is the dyno result
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827799
Impressive graph, good midrange.
I am sure he sacrificed some top end for the midrange, but thats a very very streetable tune and favorable to the extra kg's of the Stagea
/good to meet you today
Well nice to meet you too today. Im sure with have shot loads of things to disscuss.
Well when i first called Ben in Racepace i told him what i want and how im goign to drive it. I told him im looking for durability and realibility thats the priority. Then i told him that this was goin to be a street car mostly 1st, 2nd and 3rd gear ( cant go any faster than 110km/h anyway :) ) . Hence the result of the tune. I drove it again this evening its a bit scary though when the power comes on on the 2nd and third and i have to back out on the gas pedal.
Pverall im pretty pleased with it despite it didnt make the 250kw@wheels. But its enough i guess. Enough to kill the FPVs and the HSVs drivers. muahuhauhauhauahahu!!!!!! :dry:
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2828408
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
