Hi everyone,
As the topic states i'm just curious to know wether 550cc injectors are essential to reach the goal of around 250rwkw? Alot of people tell me that its better to get them but i've been offered (quiet often) sets of 440cc S15 injectors new and used. I'm just wondering if i can get away with the 440s and a fuel reg as i'm going to get it tuned pretty soon.
My engine mods are:
GT2876R
Power FC
Fuel pump 040 (or any other suggestions?)
full exh.
I/C
EBC
Z32 AFM
Also i'm only planning to run under 1 bar around 12-13psi.
Thankyou all in advance and I apreciate any input... :)
George
I've heard from both SK and Hitman that stock injectors and fuel reg are good upto about 240kw. However with a GT2876R it would be pretty silly :nyaanyaa:
Yea thats true, but i suppose you need to look at the condition of the standard injectors aswell if your making that power. When I buy injectors they'll be brand new as much as 2nd hand ones are tempting but i just wont want to take that risk on the motor.
Has anyone heard much about the SARD 550's at all? They are going cheaper than usual at the moment for a decent injector and i'm sort of considering buying them, otherwise i've found brand new set of S15 440s for a couple hundred cheaper but just not sure. Thanks again for the input everyone, all is apreciated.
I am making 252rwkw with stock injectors with out a problem. I have sold (pending payment) my 555cc injectors and will buy again when I do a rebuild for the next stage.
Thats pretty good dude, but yea i just don't know my car well enough to trust it with standard stuff when its going to be making that sort of power. I suppose every car is different and react differntly to certain things you do to it. But no chance i'm using my standard injectors when i go for the tune.
i would rather have them in the car to be honest, but the tuner did not want them in, said to do it next time and i need the money for other things now...
  • 5 weeks later...
Don't know how you'll go getting 240rwkw @ 12-13 psi. I would've thought you'd need 15psi plus. 440's will do it fine - I've got 550's and 250 rwkw and they're only at 60%.
Cheers
Cheers
Yea well you never know what happens on the day of the tune, besides who knows exactly how much kw cars push most dynos give you a higher figure than what your car really has.
For example, I tuned my car with my safc @ chasers, i only had full exhaust system, fmic, bleedvale @ 12psi (that didn't even hold boost properly), pod filter and thats about it, the dyno sheet said 214.9rwkw, now thats hard to belive....
Every cars differnt but i'm just saying if i dont get upto 240kw on that much boost i dont really care anyway, i'm not after a power figure i just want everything to work the way its set up to... And with the turbo i've got and the setup i've got i just want everything to complement everything else. I just want to be on the safe side really, but seems like 550s will be the safest choice ey...
Thats why shootout mode was invented, so I would have the same power readout in Canberra as someone in Sydney. Because things like different atmosphere and temperatures and the like.
So how can it be deadly accurate? A lot of people i've spoken to have said its rare to get a place to dyno your car that will give you a 100% accurate reading... is this true?
DD Shootout Mode doesn't improve accuracy so much as it improves parity between different dynos.
Ahuh... so how do you get a 100% accurate reading? or is it impossible cos theres 2 many factors that could effect it? wheel spin and all that shit?
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
