Hey all,
Im currently building a audio system ~1000WRMS. I was told its a good idea to upgrade your grounding points. Also heard that the Skylines have been known to have bad grounding points. Anyone had a problem with this? :)
As for upgrading the grounding points, is it just a matter of adding a few xtra 4Ga grounding cables to my -ve terminal: -ve to chassis, -ve to block? Any other points i should be focusing on?
Cheers.
https://www.sau.com.au/forums/topic/150824-xtra-grounding-points/
Hey all,
Cheers.
Yea that'll help ya a bit, probably need to add extra grounding points in the engine bay and to the battery (i think) cos i know my r33 for sure has an earth issue.
Best spot to ground your amp is to thick clean metal, using a big ass bolt, try and find some factory bolt and clean up the surface a bit aswell should be ok, you just don't want engine noise if your going big stereo n all.
the people who whinge about skyline grounding points are probably running bullshit power that the stock wiring system was never designed to cope with.
Which is why im asking if xtra grounding points will help. Btw person who told me he had problems with grounding wasn't running big @ss power hungry amps, stereo looked stock, car had 300rwkw not that this affects the current draw much.
Anyway which grounding areas should i be looking at upgrading besides -ve terminal to chassis & -ve to block? Someone mentioned to me that u can use a busbar like one below. Doesn't look to presentable tho.
If I were you, have a search for the Apexi grounding unit (or those other brands that come in a blue box), and see what the manual says. From memory, there was the block, the alternator housing, somewhere around the strut towers... and a few more.
Maybe even just look through apexi's manuals and see what their kits ground?
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
