If you do your research you will find that the cat is actually one of the most restrictive items in the exhaust system. There is no point in having a great cat back exhaust if your only going to bottle neck the flow before hand. Also if your exhaust is still original from day one its more than likely completely rooted inside.
Conclusion: Deffinetely get yourself a good 'high flow' cat that has good size inlet/outlet so it doesnt restrict the flow there either.
Deren
https://www.sau.com.au/forums/topic/150847-stock-cat/#findComment-2811234
