Ok, so i have my baby back from Tunehouse in Marrickville. My car went from 140.9rwkw, now i have 204.5rwkw. My torque figures went from 1027.2Nm @ 5196rpm to 1518.3Nm at 4473rpm. very happy with the results. i also replaced the oxygen sensor, now i just have to hope the fuel economies are better...
My mods are:
3.5" turboback stainless Xforce exhaust
Apexi Pod Air Intake
GFB Stealth FX BOV
GFB Atomic Boost Controller
Front Mount Intercooler
Apexi Power FC
That is very decent power from the mods listed.... Interesting..
  • Replies 135
Kennedy,
I stuck with my turbosmart single stage
and I only have a 3 inch dump pipe, not split and standard cat.
Oh, yes, standard turbo and injectors
Ryan - Hows it going mate??
Yep, was Unigroup!
and extremely impressed!!
I'll post up my results when I get a chance, I know Im lazy.. ;)
My mods are:
GFB Stealth FX BOV
GFB Atomic Boost Controller (running 13psi)
Apexi Power FC
Thats about right for 13 psi. If your running standard turbo and you constantly hit WOT/13psi the ceramic wheel wont last long. I know of guy who have blown turbo's at 10 at wakefield
Kennedy,
Standard cat? Man change that cat and welcome yourself to the world of 200RWKW+
Hitman did mine and it was top. AFR's at 11.7. Also, The e-01 held dead straight all the way to my new redline of 7200RPM.
yeah its rare i hit 13psi boost. im not really a super racer but i love to drive hard occasioally. just been for a trip to noosa on the sunshine coast. at first i was very unhappy with the fuel economy but it seems to be getting better. at first with highway driving i was still only getting 350kms per tank...after 2 tanks it seems the power fc is taking more notice of the O2 sensor and i now get 500kms per tank. with highway driving i would still like to see this around 600ks highway and in the city i want at least 400kms to a tank... i guess we'll wait and see.
the next purchase for my car will either be a set of tein coilovers or a new turbo! any suggestions, nothing to expensive.
A lot of good press for UniGroup on thier expertise with a PFC, BUT weren't they producing thier own ECU that was suppossed to be pretty good for SKylines as well some time ago?
I think it was a piggy back but I have an RB20DET Auto so cant use a PFC, or can I?
UniGroup use an ECU called TSI which is made in Australia. TSI are the makers of FPV (Ford Performance Vehicle) ECU's in all the XR6T, Typhoon, GTP .etc. Its on their site.
Personally for a big build i would use CRD. They offer excellent service and proven performance.
For a tune I will always use J.E.M cause i have delt with them many times in the past and Adam has always delivered the best results. Even ask BU5TER his R33 was tuned by J.E.M @ 441rw/kw with 1/4 mile time of 10.5 @ 130 MPH.
Cheers
Edited by QRI05E
I think you might be confusing unichip with unigroup. two different companies.
Hi all,
I read carefully all the comments and I would like to share with you my story. I own an 1993 R33 GTS-t and after 2-3 years I decided to do some mods. When I start the mods I joined SAU and read different articles and different posts. I done pretty much everything you can do to my car: POWER FC, Manifold, injectors, ignition coils, intercooler, fuel pump, etc etc. Bought lots and lots of parts on e-bay and here on traders.
I needed an tuner and from our forum I picked up Yavuz, Unigroup. I went there told him what I want and got a quote. Sounded all pretty good so the work started. As you see was more than a ..."basic tune". We hit lots of walls, and up to 200kw was OK but I did not get the really big numbers. I wanted something between 270-300kw at the wheel. I spend twice the amount I was quoted in labour and tune but the result was still not there. Here is a curve of the best tune I achieved at UNIGROUP. Yavuz found a reason for everything but I was not looking for problems, I was looking for solutions. MY WASTEGATE WAS FAULTY and he refused to spend more time on it. I went back a couple of times, charged me some more but performances did nto change.
Please look at my curve, up to 220kw, all power came quick than more RPM's meant flatter curve. Engine did not GOOOOO. So I told to myself I reached Yavuz's limitations.
I started all over as my car is just a weekend car so, I could afford to do it. Head came off, reconditioned, TOMEI cam shafts, changed intercooler (HKS) replaced my beloved Mick metalcraft, Plazmaman plenum, changed flow in engine, start looking like a GTR. Internals still standard on engine. My bad decision was that I found a mechanic that done it in his backyard and the quality of his work was really poor and even $10.00 if I payed was a total waste of money.
I took this car to John at Unique (UAS). I told him my story and .... after 4 weeks of fixing every little problem I had could go on the dyna. You guys should see what checks are done there before your car goes on dyna and what checks you get from Yavuz, than you can tell the difference.
True my bill was fat, but everything was done before had to be redone. Bolts on my manifold had to be replaced as too weak for new manifold, they start breaking. Lots and lots of other problems have been identified and fixed. Even my engine mount was broken and replaced and properly secured. Fixing my wastegate was not a problem, was just a little something for Richard to fix. I told John I will not pay if there are no performance improvements
When car went on Dyna I got a call from Ben and asked me how much power I want. He said that he can give me easily 300+. I stopped at the modest 270kw at the wheel which I think is more than enough for my little GTS-t. When you take your car to tune be prepared for other problems to be identified which no other mechanic will tell you about so you do not know about.
When car was finished I went and show it to Yavuz and he did not have much to comment on it.
The conclusion is that if your car is not mechanicaly 100% before going on the DYNA, engine will not perform, as simple is that.
I stop my story here and if there are any people interested to find more details please feel free to message me.
NOW MY CAR IS DONE....it's left just to learn to drive it ...properly. I GOT A DRAGON AND I AM NOT AFRAID TO USE IT.
Cheers,
EUG.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
