For Sale - 1994 Series 1.5 Nissan Skyline 2.5L Turbo
Lowered to $16,550
My precious mistress of a skyline is up for sale as I have to get myself a more "family friendly" car now due to me finally growing up....shame. The car is a little over a year old and I am the first owner since I hand-picked picked it from the Japan auctions in late 2005. The car has really never skipped a beat and the build up of my pride and joy has been a fantastic journey fuel by love of the perfect combination of daily driven ability coupled with the strength to pull off a track day. Mods are listed below and are mostly of a functional nature and not for looks and cruising.
Hardware
* Front Mount Intercooler
* CES Split Dump Pipe which separates the Wastegate Gasses from the Exhaust for a strong top end acceleration
* CATCO Hi Flow Cat
* Kakimoto 3" Exhaust
* 3" Stainless Intake Pipe (The one that leads to the turbo)
* Hi-Flow Pod Filter with Aluminum Heat Shield
* 17" Genuine Work Rims wrapped in Bridgestone G3's. Sizes are 235(F) and 255®
* Genuine Nismo Fuel Pressure Regulator
* Exedy Heavy Duty Clutch - Single Plate "organic". This is suitable for up to 250KW but still retains the factory feel and does not cause cramps in traffic
* Hi Flow Fuel pump (Z32)
* X-Force Front Strut Brace (Nismo Style)
* JIC Coilovers
* Bendix Ultimate Brake Pads
* JDM-33R Number Plate is included
Electronics
* Apexi Power FC Engine Management System
* Greddy e-01 Electronic Boost Controller with LCD Screen and Remote Control
* Both of these items have been recently tuned by "HITMAN". The car makes 201RWKW now at 10psi of boost.
Interior
* Recaro Drivers seat - (I have a matching passenger seat aswell but it is not installed. This is included in the sale)
* Genuine RPM 4 point Harness with eye bolts already installed so harness just clips on or off when needed
* Sony CD/MP3 Deck with remote Control coupled with a Sony 10 disc CD Stacker in the boot
* Genuine Nismo Leather Gear Knob
* Triple electronic gauge set in DIN slot showing Boost, Water Temp and A/F Ratio
* Stainless Cluster surrounds
* Tinted Windows all round @ 30% (Legal Limit)
I took the car to a track day once every 3 months for the past year and twice to the drags. The car has never skipped a beat and knock/pinging levels have never exceeded 25. The oil and filter was changed every 5000 km's OR directly after a track day...whichever came first. Oil was always replaced with "ELF Excellium 10W 50". The oil filter was always replaced with a genuine Nissan Item. Spark plugs are only 5000 km's old and the car has never been boost past 10psi
The car is garaged every night and washed every fortnight at the car was cafe next door. The car is available for inspection and test drives for serious bidders only.
Please feel free to ask any questions. The price may vary if you wish to exclude certain items from the sale (eg harness, EBC). Please feel free to give me a call or shoot me a message to request additional information. I hope that this car's next owner will take care of it as much as I have as alot of love and time has been dedicated to it.
Rego till Oct 07. Would consider a swap for a Starlet GT (EP82) with some cash my way.
Cheers,
Sam
0406315013
Wow what a shame man! Got anymore suprises!?!
When i was at powerplay the other week a stagea came in and i was thinking the exact same thing....
This car is what got me into skylines and end result was me importing one! Well worth asking price, great car.
Yep. The harness is RPM. It's a simple clip on item that latches onto eye bolts rather than bolted in so it can easily installed/removed for track days
  • 4 weeks later...
Car is up for sale again. PFC and recaro seat are no longer available. Need to sell ASAP or swap for a GT Starlet or something similar (small/quick/efficient)
New price is $16K
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
