probably not real c/b dude....
real c/f is like $1200+
I have never seen a fake carbon fibre bonnet as there is no plant i know of capable of dipping such a large object nor would it be of any financial gain to do so.
I think you mean or what you should mean is this.
Carbon fibre bonnets purchased under $1000 are usually fibre glass based with the top layer being carbon fibre.
You get the look but not the structural advantages that you do with a complete carbon bonnet.
This is much cheaper and what most cheap Carbon Fibre bonnet makers do.
It is still "real" carbon fibre.
totally different car here but the last quote I had for a real on e was excess of 2.5k full CF.
Eastbear, Stout, Jun full carbon fibre bonnets are around $850-1300 plus delivery from Japan.
Its just unfortunate that delivery costs so much :P
Also when a full carbon bonnet has been made within Australia and has been crash tested this will see a large increase in price.
Its just unfortunate that delivery costs so much :glare:
Been done Aaron, Custom Carbon has bonnets last I knew with ADR Stamp for approval if I remember correct
CUSTOMCARBON.COM.AU
CUSTOMCARBON.COM.AU
yep and thats who quoted me on the one for my 2006 holden combo..
Just out of interest I got pulled over today and fined for not having a mod plate for the pod and micrrotech ecu $75 no points BUT he made no mention at all about my carbon over fibreglass bonnet but then again I didnt ask either lol
WOW Terry your pod is secured... Yeah...
How did they get you on the ECU??? How did they even know???
Pod is secure, I have a handset for the microtech and he knew what it was, to be clear on this it wasnt a defect, it says on the fine "drive vehicle if equipment does not comply with the vehicle standards" (word for word there) offense details "pod airfilter, aftermarket computer" I'm not too concerned but the gist of it was, I didnt have a mod plate for anything and he wants me to get one to comply with the law, he could of defected the car but let me off with this as a warning. I have a feeling he just wanted to look at the car and then started telling me about his RX3 with a microtech and all the shit he went through with it even tho he is a cop lol. The reason he pulled me over was, I was be tailed by this total f**kwit who was tailgaiting me for ages and when I got to an intersection, I blasted through it to leave him behind, he was somewhere close and heard the roar and blow off.
i knew that mr-toy i just made the post cause ive seen a few ppl around wanting c/f bonnets cheap...i thought that was cheap
2 yrs ago mine cost me $800 in Hong Kong, it cost $3-400 to import.
why bother paying that much for something that you can only use on the track but i dont have a car so thats just my opinion
My bonnet had a acid rain look to it and a good respray was quoted at $750, this way I get a spare bonnet and no respray hassles, straight up bolt on all I had to do was switch the water spray nozzles.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
