probably not real c/b dude....
real c/f is like $1200+
I have never seen a fake carbon fibre bonnet as there is no plant i know of capable of dipping such a large object nor would it be of any financial gain to do so.
I think you mean or what you should mean is this.
Carbon fibre bonnets purchased under $1000 are usually fibre glass based with the top layer being carbon fibre.
You get the look but not the structural advantages that you do with a complete carbon bonnet.
This is much cheaper and what most cheap Carbon Fibre bonnet makers do.
It is still "real" carbon fibre.
totally different car here but the last quote I had for a real on e was excess of 2.5k full CF.
Eastbear, Stout, Jun full carbon fibre bonnets are around $850-1300 plus delivery from Japan.
Its just unfortunate that delivery costs so much :P
Also when a full carbon bonnet has been made within Australia and has been crash tested this will see a large increase in price.
Its just unfortunate that delivery costs so much :glare:
Been done Aaron, Custom Carbon has bonnets last I knew with ADR Stamp for approval if I remember correct
CUSTOMCARBON.COM.AU
CUSTOMCARBON.COM.AU
yep and thats who quoted me on the one for my 2006 holden combo..
Just out of interest I got pulled over today and fined for not having a mod plate for the pod and micrrotech ecu $75 no points BUT he made no mention at all about my carbon over fibreglass bonnet but then again I didnt ask either lol
WOW Terry your pod is secured... Yeah...
How did they get you on the ECU??? How did they even know???
Pod is secure, I have a handset for the microtech and he knew what it was, to be clear on this it wasnt a defect, it says on the fine "drive vehicle if equipment does not comply with the vehicle standards" (word for word there) offense details "pod airfilter, aftermarket computer" I'm not too concerned but the gist of it was, I didnt have a mod plate for anything and he wants me to get one to comply with the law, he could of defected the car but let me off with this as a warning. I have a feeling he just wanted to look at the car and then started telling me about his RX3 with a microtech and all the shit he went through with it even tho he is a cop lol. The reason he pulled me over was, I was be tailed by this total f**kwit who was tailgaiting me for ages and when I got to an intersection, I blasted through it to leave him behind, he was somewhere close and heard the roar and blow off.
i knew that mr-toy i just made the post cause ive seen a few ppl around wanting c/f bonnets cheap...i thought that was cheap
2 yrs ago mine cost me $800 in Hong Kong, it cost $3-400 to import.
why bother paying that much for something that you can only use on the track but i dont have a car so thats just my opinion
My bonnet had a acid rain look to it and a good respray was quoted at $750, this way I get a spare bonnet and no respray hassles, straight up bolt on all I had to do was switch the water spray nozzles.
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
