Sorry to take over your thread ratz26 but..........
I was just rereading this fine that i got and it states that the street is AVACODO st Elanora, a quick search on wereis came up with zilch! sooooo does this mean I have a chance of dismissing this fine with no trouble or do I have to take it to court to prove the officer was in the wrong on account of this mistake.
I was just rereading this fine that i got and it states that the street is "said" st Said Place, a quick search on wereis came up with zilch! and in fact the road I was on was "Other Said" st, sooooo does this mean I have a chance of dismissing this fine with no trouble or do I have to take it to court to prove the officer was in the wrong on account of this mistake.
Terry as far as I know all details on the ticket MUST BE CORRECT if there is one mistake it "MAYBE" dismissed just by contacting a Senior Sargent in that Station, if not as you say court is the next option...
i was talking to acouple a while back who own an XT forrester, and got custom carbon to make up the mould for them, (which they payed for) they also had to get it tested etc at there own expense, anyway final price for there bonnet on the forrester xt was $6000K.
OUCH! is what i said to them lol but i guess they payed for all the r&d to be the first to have one adr approved for that vehicle.
also i had a fine which was stated wrong i sent it back to the police, with a letter stating what i thought was wrong with the fine, and what it should have been, they re-issued the ticket to me with all the stuff fixed up on it so i still had to pay it.
so if u do end up sending it back dont tell them what the street name was or anything, just state that the street name of the offence is in correct, dont elaborate on the info any further. see how u go.
Edited by 85URK
Yeah Nay had a speeding ticket dated 2008 a few months back and when she pointed it put to the Police they just re-issued the ticket with another 28 days to pay the fine...
Noy's bonnet will cost you upwards of $3000 as it has ADR approval. 100% CF and looks fantastic!!
Noy put the 'tas' in 'fantastic'... His bonnet has to been seen to be believed...
Words do not describe the art he can produce...
doesnt Noy do em? and arnt they real? price?
Yes, when you say real - you mean 100% CF, NO fibreglass at all... our prices vary
and our work is matched by no-one...
where is noy?
I'm here :)
Been done Aaron, Custom Carbon has bonnets last I knew with ADR Stamp for approval if I remember correct
CUSTOMCARBON.COM.AU
The testing was stopped due to a change in our process because of the carbon shortage..
but as soon as our carbon arrives expect big things from Custom Carbon and ADR approvals
here's a few pics of that bonnet
Awwww shucks lol and yeah my bonnet is a 1 of a kind, guess it cost money to be different.
If anyone has any questions about carbon fibre don't hesitate to ask, i'll do my best to answer all questions..
Thanks Noy
Edited by Noy
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
