Guest INASNT
Originally posted by predator666
russcb007: thats a pretty good idea.. i had a standard set of springs but unfortunately had to sell them for some $. Have a standard set of wheels around if anybody needs them for any purpose..
yeah, but isn't the whole idea they are testing the emissions.. not just which doovas they have which might change the emissions?? In other words, they don't really care what your car has takked onto it, as long as the emission reading (and noise) is legal. Isn't that the whole idea of the test?
using logic yes, but its the epa so..
basically they dont want u to change the factory setting even tho it might actually run cleaner with an aftermarket ecu and intake mods!
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-307605
  • Replies 42
alright, when you say that its best for the engine bay to look as stock as possible, does that mean that if there is a big a/f turbo sitting there that you gonna be fncked or what?
also with fmic, do they look for them or if it was black and covered with mesh they wouldnt even know?
what if you put the top of the standard air box over a pod?
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-308438
but if its engineered it would be fine? aaiight
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-308611
My thoughts on EPA...
I had to take my 32 there last year for heaps of reasons..... They're not stupid and will spot all of the following:
ANY sort of boost controller - trust me I spent ages hiding mine and he spoted it in 2 minutes
Any sort of oiled filters are ILLEGAL
Only allowed 1 inlet modification, filter or cooler or inlet plenum etc etc... but not more than one
Removable silencers are passable if the securing bolt is welded in
ANY sort of air/fuel or timing controllers are illegal, and they frequently remove the kick panel to check ECU and wiring associated with it.
When I went over and passed, I had FMIC, non-oiled pod Filter, 300ZX AFM, custom chip in my ecu, welded in silencer (89.8 db with silencer!!!), and a high flowed VG30 turbo.... the only thing they picked was two inlet mods but let it passed anyway. My chip passed emmisions test with flying colours... they even commented that it was way below the maximum allowed and heaps less than most other skylines....
Good Luck with your test...
Doc.
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-308713
NO!
engineers approval and EPA approval are two separate things.
Engineers is for brake/suspension/diff etc etc.
mods that don't affect Emissions.
EPA test (worth $2,500+) is the emissions test to get it approved (if you want) with the alterations like zorst/safc/boost/big turbs etc etc.
If you fail you don't get a refund or a second chance.
Same test that all new car models must go through.
I'm gonna look at doing it to mine once i'm finished in a few years. That way the cops can't defect you for anything as it get's the EPA approval with all mods listed (same as engineers)
I've said this all before so i'm not going to go into more detail.
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-310027
mmm... nice indeed.
that's why they pin you for not being stock - safc's and boost controllers and stuff.
ha!
wish it was that simple as them doing it while you are there!
but i think to get the cert. there are more test's to go through.
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-310041
First of all,
Guys stop kiding yourself, these guys that work there arnt fools!
Covering a FMIC with some mesh isnt going to cover it, when i got done and went down to mcloed(spelling) i disconnected my Turbosmart boost controller (incabin) and wraped the hoses around the wiper leads. The barsted opend my bonnet and that was the first thing he looked at, then he said "$500 fine if that was connected". THen he opend my airbox, checked my intake for BOVs, followed all intake tubing/hoses . Then he checked exhaust/cat and done the DB test, checked CO/2 levels. then said nothing here, see ya later son! (10-12MINS)
Change you exhaust to a stocky, check your cat, replace your stock air element, and change your oil if your really para. Then after the EPA take your exhuast OFF, air cleaner out, Hell stick a mega huge triple trumpet BOV and roar past there with you plates fliped up! :shake:
*** you EPA & junior cun*tibles pricks i hope your reading this, you may be able to inconvineince us, but youl never be able to stop us.
https://www.sau.com.au/forums/topic/15089-epa-action/page/2/#findComment-317624
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
    • How good is it though when you can run the AC without the engine running to cool the car off before you get in it during summer? God I'll miss a bunch of the EV features when it leaves on Monday
    • I hear you were headed for a track day yesterday... Thread clearly needs updates
