  • Replies 42
Some time ago someone (presumably a cop) had reported me to the EPA for excessive noise pollution.I got a letter from EPA which said that I had to go to one of approved (they give you a list) exhaust places,get them to mesure the noise,recieve a certificate and fax it back to the EPA to get clearance.I went to my friendly local exhaust place and asked for advice.Ididnt really want to change my exhaust.What they done was cut a piece of aluminium in the shape of a flange which joins the cat and cat-back pipe.Drill 3 or 4 very small holes in the middle and slip it between the cat and the cat-back.Cant really tell from the outside.I took the car to the approved joint with a green on my dial whatching him.At this point I have to mention that I took my car there the day before to mesure what my noise level actually was.After parting with the required $50 I was informed that noise is 108 db and then they tried to sell me new exhaust.Now, he was frantically going over and over trying to figure out why the car is so quiet all of the sudden as everything was seemingly exactly the same as the day before!Fu*king looser.It surely was one of this "Mastercard moments"-priceless!!!Anyway,He wrote down the indicated 87db on the certificate,which I then promptly faxed back to the EPA.Rang them up to confirm.Took the "restrictor" out.End of story.
Cheers
https://www.sau.com.au/forums/topic/15089-epa-action/page/3/#findComment-318451
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
    • How good is it though when you can run the AC without the engine running to cool the car off before you get in it during summer? God I'll miss a bunch of the EV features when it leaves on Monday
    • I hear you were headed for a track day yesterday... Thread clearly needs updates
