  • Replies 255
it's taken me a while but here are some of the photos i took on the day. i haven't had time to look at any of the others, i'm afraid. it wasn't so easy to get wider shots of any of the cars because they were parked so close together. also i've worked out that shooting cars isn't easy! i have a lot to learn.
yaha cheers chaps. actually i don't have a lot of experience shooting people - more stuff that i can control and position. same goes for lighting. so shooting cars that someone else has parked, with broad daylight and only one lens was bloody tough i found.
but mark (?) was sitting there and the composition was right so i started snapping. i think he said something like 'what's this for?' and i was tempted to say 'autosalon' or something but i told him the truth. :( i think that shot in particular could do with some post work. would look good in b+w. also have a couple more of mrs.gt, jayce. they'd look good with more work too i think.
i'm always up for a shoot so if anyone wants to do a photoshoot or summat i'm keen.
Sorry to rain on the parade,but that'd be a gold Foz,not a Stage' in that reflection. I can understand how you got them mixed up; family wagons,both,with a bit more go than expected in each...LOL! It's all good,Termi'; it just means you can lay a good guilt trip on Sig' for missing your car,and pestering him for an exclusive photoshoot,LOL!!!
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
