ok
a mate bought a brand new hand controller from kudos - for his sr20det - hand controller came - plugged it in and it froze on the apexi logo.
wrong controller :/ - so sent it back and got another one from somewhere else.
finally came today (second hand unit) - plugged it in and now there is nothing - no freezing, no light up, no picture or writing. nothing. it was supposedly to suit a sr20det.
if any hand controller is plugged in i was under the impression that even if it is incorrect, it will still start up and then freeze on the apexi logo?????
hand controller number is FCCNT 9805 - 0023
BUT!!!!! - i plugged it into my ap engineering rb20det power fc - and it lights up and i can view everything and it works perfectly!!!
My mates SR power FC serial no. is PFC SR202R 9812-033 . this was also bought second hand. And my ap engineering power fc is brand new from box about 2months.
So i was under the impression that brand new units and older units were not compatible with the older handcontrollers???
so wtf??? anyone got any ideas on this situation - as to why the hand controller isnt even lighting up and freezing with this one
thanks
-Matt
https://www.sau.com.au/forums/topic/150906-power-fc-handcontroller-problem/
According to Paul's FAQ, Apexi product chart says that for an SR20, compatible FC Commanders have a serial FCC NT (1st gen) or FCC FN or FCC3 (later releases).
So it looks like your mate has the PFC that requires a FCC FN or FCC3 serial FC Commander.
let me know once you sort it out, will update the faq if something is wrong
if its not even powering up some else is bogus. if the hand controller is wrong it fails post diag and locks at the apexi logo. open the hand controller and see if its burnt or smells burnt. i suspect its dead or something else is busted.
well thats all it is worth to me, i will pull it apart and salvage the screen and anything else, assuming they arent toast. try and return it back to the supplier as DOA and get your money back, if not throw it in the bin
sorry guys the HC is fine its the pfc thats stuffed i.e water damaged
it doesnt seem to want to power up the HC although the PFC still seems to run the car fine for now
and the HC runs fibe on Huddys FC
Edited by 1400r
bit odd, maybe the pfc socket for the hand controller is toast?
where is the "water damage" idea coming from?
when u open up the PFC do you see any burnt or damaged stuff? does it smell? check the pins running to the PS2 socket for the hand controller
hey ryan post a pic up !
the water damaged seemed to off come in through the plugs for the handcontroller (from memory)
it is just odd that with another hand controller that 1400r had before it DID load up and freeze on the logo, now with this one - it does nothing (BUT works perfect on my rb20 AP PFC)
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
