You might want to edit that as it made no sense at all.
An 044 intank is no problem if you use an additional sock filter on the inlet. Orientation isn't an issue with it at all.
If anything I would be more worried about the limited filtering capacity of the 040 pump filter screen.
The 044 does have an internal filter screen as well, although the mesh might keep out things like.. medium size rocks perhaps?
My question was pointed more at eXc as he has reported 044 intank failures and I was wondering if he had used an additional pickup filter, but then having one bad out of the box I probably would have been asking more questions of the supplier, than the pump install itself.
James.
SECUR1TY's install is an 044 and they dont like being in a tank at all.. the ( 040 ) has a filter built into the bottom of it and they are designed bo be used in an upright position unlike its 044 external brother..
so if you are using in 044 in your tank no wonder it died...
  • 4 months later...
Quick query:
Heatshrink. will it react with petrol.
I only ask as I soldered the connectors on to the wire, but it looked messy, so I used heatshrink around it, then on the terminals too (figure that avoiding a spark in the tank isn't a bad idea)
Anyone know if it'll perish or even worse, heat up?
I did a quick test with some fuel and a strip of heatshrink, and nothing seemed to happen, but just thought to ask.
  • 3 months later...
alright i am in the middle of doing this now, and i can't for the life of me see how you can put this in without cutting the metal pipe that the pump connects onto via the hose
it is simply too long...
Good to see a tutorial on this but there are several issues I see over looked all the time.
A. 040 and 044 are massive over kill unless you are looking at supplying fuel for a hugely powered car. (in which case, an in tank simple set up is lacking in every department)
B. no check valve on either of these pumps. So as soon as you stop the car, all pressure is lost.
C. I don't think I've had an R32 that you could bend the pump seat down and fit it back in
D. this mounting style will be tremendously noisey.
Not being a smart arse! just trying to give info that I have come accross the hard way. I recently revised my in tank bosch set up but the pics are on my work computer. I'll get them up soon.
Thanks for the comments, other peoples experiences are always good when doing something like this. My views however;
A) It's what 'everyone' on the forums here seemed to go for, which is why it continues to be a popular choice (even though now I'd say buy a walbro, cheaper, i had less problems and it would fit in the standard mount)
B) No idea about that, but it didn't cause me any problems - Unless that had something to do with me going through 2 of these pumps...the walbro never had a problem... so it could be? not sure why I went through 2 Bosch's cause the tank was not contaminated.
C) Like I said in the tutorial, you need to cut it down.
D) Wasn't noisy for me at all. The Bosch was much louder than the Walbro however.
Cheers
Chris
  • 3 months later...
I just installed one today. For some reason if I was to mount mine directly under the fuel feed pipe it would not fit in the tank. So I mounted it on a very slight angle and put a loop of hose around back to the feed. This actually worked really well. I only have 10l in the tank and its fine, its only slightly louder than the standard pump.
I also did the fuel pump rewire because the standard pump was getting just under 12v.
I have heard that at low throttle position (less than 10%?), the voltage drops to 6V to cut noise down. Is this true? If it is this may be the reason some peoples pumps don't last long as they are burning out if they are using the factory wiring to power the pump.
Mine was around 12v mark at idle...so i don't think that is true, unless it drops voltage when you throttle it a bit, which I doubt... measure it for us and let us know,.
Were you measuring voltage from the positive terminal on the pump harness to chassis ground or the negative terminal of the pump harness? The voltage regulator module for the fuel pump lifts the ground to reduce the voltage seen at the pump.
  • 4 weeks later...
yeh sure is true, i jus put a 32 gtr pump into my gtst and when i start it up after about 5-10secs you can hear the pump slow down then if i give it a little rev it will speed up again pointless to me but yeh
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
