Can anyone out there please tell me how to tell the difference between a standard R33 GTR and a V-Spec Model.
I know the obvious one - the V-Spec has an Active LSD withe a couple of wires coming out of it, but what else is there that I should look for ? I am in the market for a GTR, and am looing for a V-Spec in particular, but want it to be the real deal.
Is there not a way you can tell from the Chassis number or something like that ?
Any help would be much appreciated !
Cheers
Woza
https://www.sau.com.au/forums/topic/150926-how-to-identify-a-true-r33-v-spec/
The vehicle serial will have a W
The AWD is controlled by a slightly faster processor
it has a sticker on the back and
it has a pox active rear diff that no-one will know what to do to fix it if it goes bang
oh and the buyer has probably wasted about 2-5 grand over a "standard" with a proper 2-way diff which would have paid for replacement suspension since the slightly firmer V-spec suspension has now shagged it.
So GTRGeoff.....I take it you are not a fan of the V-Spec ?
to be honest I would like some guidance as to whether or not I should get a V-Spec or a normal GTR. From your response it sounds like I shouldnt ?
Any other opinions etc out there ?
Edited by woza01
different suspension (but like mentioned already, probably already been replaced)
active lsd
attessa pro
I think the 33 vspec is not as rare as the r32 vspec so not realy worth alot more than the normal 33gtr. The extras can be handy but not realy a must have
There is basically no difference on the track in terms of laptimes, and as the cars age the diff is a real negative in terms of repairs if they go so that is a lot of money to pay for a $5 sticker. One of the members had no end of trouble diagnosing and repairing an active diff on a GTS25t S2.
Now if it was a 32 there would be a quantum leap in processor speeds and the 17" wheels and Brembo brakes so a worthy purchase (not to mention a later model and not a 89 model as is prevalent).
On a 34 the extras are quite significant but includes the underbody aero fittings as well.
Just do what a previous owner of mine did and buy the schticker. It means nothing to those that know but the playstation generation will wet themselves.
there is a whole heap of extra bracing underneath the car to stiffen it up more
basically pay no more , but if you find one then meh you might as well get it and be cool with the v-spec sticker at the back
Edited by arkon
Easiest way to tell is have a look at the rear diff.
V-Spec's have fins on the diff for cooling - Non V-Spec's do not.
I must say that when I was first looking for my GTR, I HAD to have a V-Spec because they were the better car (supposedly). Ended up with a standard GTR - couldn't be happier.
The average mortal would not be able to tell the difference in performance between the two.
Anyone who says they can is pulling their pud!!!
Look for the best car (condition) - not whether it is V-Spec or not.
^ yep the finned diff is the easiest way, but that can be changed easily, especially if the car has had a diff upgrade. My R32 has the finned V-spec diff cover, but it couldn't be a V-spec because it's an 89.
But as everyone says, it's not really gonna make much noticable difference except being able to say "it's a V-spec"
I'm still yet to see it or any documentation regarding this. The couple of V's I've looked seem no different to mine but they were quick looks and there may be something there.
I would like to know more too , all the bracing looks 100% factory and knowledgable performance workshops pointed it out as the v-spec bracing.
its quite noticable , all around the diff , rear axel , exhauist and up in the front of the chassis too
its a real pain to cause it knocks against my exhaust so if its not factory ill rip it out . it looks very very factory though....
i can post pics next time its on the hoist if it helps
Edited by arkon
Actually it was more than that, the A-lsd fix for PFC has been sorted for quite some time now. Oil problems this time but still an expensive fix for such a simple problem. And another A-lsd problem has occurred today as well.
The easiest way is by checking the ID plate ( blue plate on the firewall), as others said it has a W instead of a G in a none V-spec.
There are a lot of other differences, some very minor but everything can be changed so the ID is the best way .
There is NO extra bracing under the car in a V-spec, they are all the same V-spec and none have the same bracing. The finned diff is a good indication as is all the plumbing that goes to it . ALSD on the cluster ( how easy is this to change) . Brake ducts on te V-spec directing more air to the brakes is another . The strutts are different ( same colour so they look the same and they are interchangeable) and the ride is a little lower on the V-spec.
Other stuff is more difficult to see without taking stuff off ( like computers)
  • 3 weeks later...
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
