^ yep the finned diff is the easiest way, but that can be changed easily, especially if the car has had a diff upgrade. My R32 has the finned V-spec diff cover, but it couldn't be a V-spec because it's an 89.
But as everyone says, it's not really gonna make much noticable difference except being able to say "it's a V-spec"
All R32 GTRs have finned covers, unless they're late '93 or '94 models, which run a plain non-finned cover similar to a non v-spec R33.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Cut and paste and you will be able to see what the cars are by the blue plate.
If the last 3 digits are 7 AA then you have GTR
8 AA then you have V spec 2 non N1
If you have dont have either a 7 or 8 and there is no number AA then you have a GTR V spec 1
or if you have 7ZN or 8ZN you have in your grubby little hands a V spec 1 / 2 N1
just put the address above in the explorer bar and you should be able to work it out.
  • 1 month later...
Geoff that was actually just the powerfc playing around with it
Actually it was more than that, the A-lsd fix for PFC has been sorted for quite some time now. Oil problems this time but still an expensive fix for such a simple problem. And another A-lsd problem has occurred today as well.
ahh!! so it was paulr33?
what alsd problem?
I had the same prob with my pfc and alsd.. the computers did not talk... a few wiring changes and voila!
i'm having more problems with my alsd though, and am looking to change it... any ideas on whether the stock 33 diff is interchangable with the alsd? or will i need to change the driveshaft and other things? anyone know!?
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
