^ yep the finned diff is the easiest way, but that can be changed easily, especially if the car has had a diff upgrade. My R32 has the finned V-spec diff cover, but it couldn't be a V-spec because it's an 89.
But as everyone says, it's not really gonna make much noticable difference except being able to say "it's a V-spec"
All R32 GTRs have finned covers, unless they're late '93 or '94 models, which run a plain non-finned cover similar to a non v-spec R33.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Cut and paste and you will be able to see what the cars are by the blue plate.
If the last 3 digits are 7 AA then you have GTR
8 AA then you have V spec 2 non N1
If you have dont have either a 7 or 8 and there is no number AA then you have a GTR V spec 1
or if you have 7ZN or 8ZN you have in your grubby little hands a V spec 1 / 2 N1
just put the address above in the explorer bar and you should be able to work it out.
  • 1 month later...
Geoff that was actually just the powerfc playing around with it
Actually it was more than that, the A-lsd fix for PFC has been sorted for quite some time now. Oil problems this time but still an expensive fix for such a simple problem. And another A-lsd problem has occurred today as well.
ahh!! so it was paulr33?
what alsd problem?
I had the same prob with my pfc and alsd.. the computers did not talk... a few wiring changes and voila!
i'm having more problems with my alsd though, and am looking to change it... any ideas on whether the stock 33 diff is interchangable with the alsd? or will i need to change the driveshaft and other things? anyone know!?
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
