I get this knock or sorta clunk in the rear from the diff area when i suddenly go off throttle. It also happens alot when im reversing and at a certain speed when im braking hard.
It became apparent after a night of a few hard launches so im thinking i might have done a CV joint.
Any ppl with similar experiences?
https://www.sau.com.au/forums/topic/150952-clunkingknocking-in-rear/
Could be a cv, but most likely the Diff. Mine has a clunck after fitting the new HD clutch, mainly as the clutch is so hard and grips so well that it doesn't prelode the drive line before disengaging, it just disengages.
this might sounds stoopid but have you checked your wheel nuts are done up properly...I had a clunk noise in the rear of my 180sx that took days and about 4 different mechanic diagnosis' to work out, we were sure it was diff/tailshaft related but jsut needed to re-tighten the wheel nuts
thanx for the replies guys.
In regards to the diff, i just has 1 rebuilt only 2months ago so i doubt it is it, but im hoping it is, since it is still under warranty.
I'll also checkout the wheel nuts 2moro, hopefully it is that :whistling:
Most "bush mechanics" ive spoken to reckon its the CV joint tho
hobzta man, u are seriously a legend. It checked the wheel nuts and for some unusual reason a few of them were loose, mayb some1 has tried to steal my rims. Regardless, problem is now fixed and u mate saved me alot of f***ing around.... so thank u
  • 3 weeks later...
Just to add, when i last had my car serviced i started gettin a clunk from the rear, got really bad.
Took to a diff shop, found one stud off and all the others lose. Were not tighted when they were removed. Another 5k, could have lost a wheel.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
