Hi all
Ever since I got my car ive noticed that the voltage fluctuates.
For example, when winding up the power windows, the voltage will go down a little, then spike down some more as the window reaches the top and kinda stops winding.
No big deal to me as I think thats probably normal.
But sometimes, when I drive, if I press the brake pedal, the voltage drops down a volt or 2 very quickly and then rises again. Sometimes little things like this happen which make me wonder if there is a need for a grounding system or something.
Does the same happen to you? is it normal? is it worth fixing with a cheap grounding kit?
Thanks all
https://www.sau.com.au/forums/topic/150971-r34-gtt-voltage-fluctuations/
Hi all
Thanks all
Hi,
The power windows fluctuation is normal. As for the brake pedal, I don't get it. Maybe an issue with your battery? I get it when the xenons charge up only for a split second though.
Yeah I think the voltage fluctuation is due to the brake lights lighting up, only happens sometimes.
I had to replace my battery since it was getting old, even with a brand new battery it still drops and spikes here and there upon things like stepping on the brake pedal.
Try turning your stereo up full volume...u'll notice tht too :rant: Its normal I'm pretty sure.
I get that. Happens when I turn on my alarm as well.
Small spikes that occur as the result of an action ie; using windows, sunroof stereo etc. shouldn't be a problem.
