Sadly I have to sell my engine as i have bills to pay and other pursuits :wub:
Specs:
RB25DET Block
Bored 20 thou
Honed
Venolia Forged Pistons
Genuine Nissan N1 rings
Balanced Crank
Shotpeened, Balanced and Linished rods (i can definately say they were done within an inch of their life with pin prick balance marks to get them perfect).
ACL Race Series Bearings
ARP Stud kit
Cometic 3 layer 1.8mm Metal Headgasket
Head completely Rebuilt including new valve seats and stem seals all new gaskets
Polished rocker covers
GReddy Exhaust Cam gear
Gates Racing Timing Belt
New Genuine Nissan Thermostat
New Genuine Nissan Thermostat housings
New Genuine Nissan Water pump
Motor has barely even been run in yet!
Does not come with turbo/exhaust manifold/inlet manifold
Im asking $5,000 for it, i doubt you could buy an RB25 for that and then rebuild it to the specs of this motor.
I also have standard inlet manifold/injectors/rail which I would chuck in for extra $250
Also have turbo kit and GReddy inlet manifold for sale see in my signature
PM or email me [email protected]
Cheers
Tim,
https://www.sau.com.au/forums/topic/150974-rebuilt-rb25-long-motor/
  • 2 months later...
How much compression is the engine running and where is the engine located?
hey
im keen on wat the compression is like aswell?
wat power is it all rated 2?
and would u b keen 2 just sell the bottom end?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
