Hey Guys,
My R33 will arrive Mid August - Now I am planning my first mod - Wanted to get feedback / input from the forum:
The car comes from Japan with:
Cat back exhaust
Pod
AFC
Turbo Timer
Suspension
Wheels & Tyres
What the first mod I should do to her ?? ie Biggest bang for my $$$
FMIC ??
Cat forward manifold/exhaust ??
CPU ??
Boost Contoller ??
Strut Braces ??
Cold Air I ?
PS - WTF does an AFC do ? I know what it does theoretically , but don't understand the benefit ??
https://www.sau.com.au/forums/topic/1510-first-mod-advice/
Guest Boxhead
the biggest hp to dollar value will be nos, however, its a bit dogy for your engine...
i was like that too mate, having money.. ready to buy stuff for car..
but my advice, is dont buy mods straight away, get your car on the road, and drive for a while.. before you do anything, so you have money just incase sh*t goes wrong and stuff.. trust me, if you have no cash, it will go wrong hahaha..
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-29645
i had similar mods on mine when i got it (cat back, hks pod and some suspension stuff) - my first mod was a FMIC and bleed valve:
following, i got an oil catch can and strut brace ...
then i finished my exhaust (3 1/4 off turbo and 3 1/2 cat back)...
this set up made 162 rwkw on 9psi..
hope this helps.
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-29653
Someones been watching The Fast and the Furious! :)
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-30281
FMIC - Front Mount INtercooler
Black33 - You can notice the difference quite considerably.. mines runnign on 9.5psi and its an animal.. when it hits boost in the dry in 2nd I lose traction and all hell breaks loose.. and ive got 255s on the rear :)
My next Mod is definatley a front Mount then run 12psi.. then after that, 3.5" dump from the turbo.. then new turbo.. then 14psi.. then powerfc, then more boost, then new internals.. then... the list goes on!
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-30377
Yip - all good stuff. My first mod on my totally stock R33 was a boost controller, followed by a K&N and turbo back exhaust (though yours already has a good exhaust thus saving a bit of coin!)
I have also spent a fair bit of money on dyno and workshop time to ensure everything was A-OK and operating at it's peak, eg changing the timing, plug gap, plugs on a dyno.
My next mod (if I don't trade the car on something else) will be a front mount followed by a ECU.
Hope you enjoy your new beast!
GW
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-30466
ex-static it might be better if you change the order of your mods.
the best way is generally boost controler. fmic,ecu for tuning s-afc or power fc. then fuel pump then turbo then dump pipe.
I'm running 8-10 psi on mine at the moment and I miss the power I had b4 so I'm looking at options.in the bigger turbo dept atm
meggala
https://www.sau.com.au/forums/topic/1510-first-mod-advice/#findComment-30669
    • You don’t need to use full throttle all the time to break these blocks, 500kw at the wheels in more then enough to break them even with an occasional squirt. Hell I’ve seen them break under 400kw
    • A work around is to install the R35 card style AFM/MAF on the cold side of the intercooler piping and the BOV on the hot side piping. Works well, also you can combat the revs dropping by adding a bit more ignition timing on the idle ignition timing table to slow the rate of RPM drop.
    • Understood. If you dont have a ridiculous limit,  Tune, T's and P's are in check, and arent bashing it all the time and doing the due deligence for maintenance(inc oil analysis) then its pretty safe. 100% agree, let your right food control it to some extent.
    • So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end   For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc  IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then  you can starve the cam journal??? I have one of these kits from bits I had years ago before plans changed  I don't understand how that tracks with this video   https://youtu.be/RuPiI22Mplk?feature=shared   This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!?   Lol.... don't v have these problems on RB20s
    • Yeah i know that MAF is no no for this type of BoV. The engine has no BoV and "hose/pipes" ..it was all deleted (or probably it was not even on the engine when it was bought  ) It does that "sutututu" noise which i kinda do not want(atmospheric is better IMO...but standalone ECU)  What are the cons of running without blow off on stock RB25DET NEO. It running 5-7 PSI max (it has boost controller)   EDIT: and can Nistune be "tuned" to know there is no BoV to i dont know "know" and be better for a car? I read so many info about no BoV. One guy saying it is bad and hurting the turbo/engine/car and other that it does not...
