Is an after market chip really that good of a bang for your buck mod on a resonabley stock car ? Cause I'm looking at getting a FMIC in the very near future (as well as getting my brakes done, machined and new pads) and then upping the boost a bit with a bleed valve. Then hopefully getting the dump pipe/front pipe done with a 3 1/4|1/2 depending on how much moneys left over.
The 32 ECU's are remapable (to a certain degree) aren't they ? Cause I read in Zoom a while ago, with a fuel pump, boost valve (to 14 psi though) and a remap they got 160rwkw on a stock 32gts-t.
Do you think a PFC for $2000 would be the best dollars spent though ? Currently all i've got as far as power performance is a catback zorst. Getting a bleeder shortly though.
I'm doing work on ecu's atm on r32's using an s-afc as well I need some dyno time to see how it goes the best bang for your buck mod you could do is to bolt the turbo from a vg 30 or an rb25 and you will make 170 rwkw hp at least at around 10-12 psi but I'd get a bigger fuel pump as well and a bigger fmic you don't need to spend 2k on an fmic if you only going to chase 170-180 rwkw you just need something bigger than what you have.
a s/hand one will do.
meggala
Well I'm looking at getting a FMIC at the minute, i'm looking at getting a decent sized cooler as i'm looking at around 200rwkw in the future. So I don't want to have to do it again. I will be looking at getting a VG30 turbo in the next round of semi/major mods. Probably with a fuel pump in between.
bump that - get a T04, thats what i am probably gunna do. :P
I am getting my S-AFC soon too, can't wait!! :P
Then i will tune for 12psi and i should be getting ~180rwkw (I am gettin 162rwkw now on 9psi with no S-AFC).
Christian
and
NOZILR!!
OK guys - that's really good feedback -
i can see merit in FMIC and boost contoller straight up. Gives colder (more dense) air and more boost (without detination right ??) Then ECU 'cause factory one is Shiet. I wanna know what dump pipe is, and what is the benefit ?? Then, bigger turbo (makes sense - more O2) After that you need more fuel right - ECU can only do so much so injectors need to be bigger right ??
Has anyone done a short shifter mod ?? Don't know how much benefit on the 1/4 it would be, but sounds like FUN.
PRANK - is there a local shop to Nth Beaches ??? Where do you go ??
OH - BTW - U F'd up my compliance papers to Canberra - sent copies instead of originals - LET IT BE KNOWN -they only accept originals - Have to make up the StfUp by lot of Canberra brown nosing. Hopefull I will have BEAST on the road by late AUG.
Cheers All.
BF
Originally posted by [ryan]
catch can is the thing that catches the oil the bov spits out rite?
i like ndr's home-made catch can haha..
No sorry Ryan,,,A catch tank is just a remote oil breather tank that stops oil mist from re-entering the inlet side of things.......Nothing to to do with a Bov at all..........
Neil.
Dump Pipe is the first part of the exhaust off the turbo - they make a big difference when you get an after market one.. i have a 3 1/4" dump pipe (HPC coated - this lowers the heat emmitted from the dump pipe and keeps engine bay temps down..)
There are some shops, but i take mine to my mate in Castle Hill - Hills Motorsports, he has done everything to my car so far and knows his ****, a few people from the boards take to him.
Cheers All.
BF
Thats a bummer dude - how much longer will this cause it to be?
Christian
Hopefully, I can fix before the car arrives - Will be moving heaven and earth to make it happen -
I work in Castle Hill - So maybe Hills is the go - Have been looking at UAS, but yeah,,,,
Cheers dude,
So dump pipe is like a BIG exhaust manifold ??? Like headers ??? Am i on the right track ??? Lets gas out quicker than standard ???/
BF
Neil.
ahhhhhhhhh ok gotcha. whats that thing u've got then that collects the oil!?
