ECU
135 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
i just got a quote for a haltec E11v2 for the car from in tune performance. anybody got any guff on these. quoted around 2700 fitted and tuned. removes air flow meter and o2 sensor. was told this is the best plug in ecu
  • Replies 162
Due to a lack of research on my behalf i am running a microtech on my rb26. the car seems to drive smoothly enough but fuel consumption is rediculous. i get max 280 km out of a tank and even if a i really baby it it doesnt seem to make any difference.
rotomotion tuned it to 320rwhp with the only mods being the usual exhaust, pods, FMIC, walbro pump. 12 psi.
At this stage i would not recommend the microtech to anyone because everyone seem to get better fuel consumption than me with similar or more power. I am hoping another tuning attempt wil fix the problem. The rear bar collects a fair bit of blackness. Weather that is due to not having a cat or running too rich i dont know.
If anyone is running microtech and can get more than 300km out of a tank i would like to know about it.
theres no closed loop function on the microtech so fuel economy is crap
its a very well known issue
Ok so basically its live with crap fuel economy or change ecu. I guess that takes the microtech out of the race then because i dont know of any advantages it has over other models to compensate for its fuel economy?
there were some threads about turning off closed loop on the power fc and editing the cells around the cruising points directly to improve economy even over closed loop operation but i didnt read in much detail
have a search in the forced induction section
For my money on my RB26DETT PFC all the way.
I do not want to pay for a whole heap of Wank features I (& about 80% of other ECU buyers!) am never going to need or use.
I dont care who has ran what ET on what ECU.
I have ran about 5 tuneable ECUs over the past 13years, the PFC is cheap, popular and flexible and is the only one I find it hard / impossible to tell I actually have an aftermarket ECU Fitted, which is what its all about really :D
The Wolf is getting me 500 to a tank - stock 20, 25 turbo, turbo back exhaust. Got 600 cruising to Busselton and back. If you put your foot into it tho it drinks a bit but regular driving if I come in much under 500 I would be scratching my head.
Bayley,
The reason your getting such good fuel economy is cause your car is running too lean. Your AFR's are dangerously lean for a turbo car, and can lead to pinging. I'd suggest you get a retune soon, cause while you may save of fuel you'll be up for a new engine.
Cheers
Paul
I got 450+km with my old R32 GTR , power FC (airflow meters) group A turbos, Tomei 260 cams (lumpy idle too) making the better part of 300rwkw and a half dead engine.
BUT. Who gives a fig! If you have a performance car you are going to use lots of fuel or you simply aren't enjoying it!
Want ecconomy? Buy a mo-ped.
Guest
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
