Hi Guys,
Had my car on the dyno today getting my pfc tuned. Asked the mechanic if we could run it on 12 psi.
This afternoon when I went and picked it up he said that he could not get any more than 9psi. He said that he thinks one of the waste gates was stuck open, does this sound right. It's a 32 gtr with standard turbos and a manual boost controller. Chris
https://www.sau.com.au/forums/topic/151108-boost-problem/
A stuck wastegate will stop you running higher boost for sure but if your mechanic/tuner can't ascertain the nature of the fault then you might want to consider taking it somewhere else. A good mechanic/tuner is worth his/her weight in gold, especially when talking boost.
Have you ever been able to run more than 9? Does it have a stock computer (My 33 GTR has the stock boost restrictor in place but was running 13psi - found it had an aftermarket computer).
2nd opinion can never hurt, try to find someone who knows Imports and particularly GTR's.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812727
THANKS it has a power fc, i got a feeling he put the boost controler on the wrong line no matter how much you ajust it still the same boost.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812793
Did you install the PowerFC? Are you sure there's not a boost control module for the PFC installed somewhere?
It does sound like he's doing something wrong though, you should be able to vary boost by 'some' amount if it's on the right line. I've not fitted a controller to my GTR (only had it a week) but on my Series II GTS25T it was installed on the vacuum line between the Intercooler pipe work and the Wastegate actuator. Make sure it's installed the right way too, if it's not it will boost all over the place and you'll be picking up RB26 pieces =\
Edited by ActionDan
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812853
yeh i put the pfc in but it's the same with the standard one.may have to start pulling shit off and have a bit more of a look.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812884
I'd be getting a second opinion before you start ripping it apart. Try to find a reputable tuner/mechanic with Import/GTR experience. Explain the situation to him so he can inspect the wastegates and go from there.
Good luck, let us know how you go :huh:
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812913
The issue of safe boost level on stock ceramic GTR turbo's is a contentious one. Many people have safely run about a bar with no issues, many others have reported turbo failures and in some cases engine damage from ceramic dust being ingested. The decision is yours but be warned that pushing the ceramic turbo's WILL reduce their life and increase the risk of failure as does pushing any component harder.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813078
yep i wanted to run at about 12.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813135
Doesn't the power FC have its own ebc therefore eliminating the need for the manual one? I got my car tuned to 13 psi and i had the power fc and eboost hooked up. The eboost was controlling the boost levels but when i went to pick the car up the engine light was on. The mechanic said "oh that just happens to skylines with the power fc" which i didnt take kindly since i entrusted my car to him. I came on here "SAU" and found out that the power fc has a boost controller that u can turn off with the hand controller. I did that and BAM! engine light gone...
In all maybe the power fc boost controller and manual boost controller are crossing paths and playing with your boost level? Perhaps disconnect one and see if theres any difference.
Matt
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2814610
Matt
maybe he has put the boost controller on the wrong hose.if i was looking in my engine bay what hose should the boost controller be on?at the moment it's on a small hose under the intake.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815546
Matt
The PowerFC Boost control is a separate part you purchase (the solenoid).
Its the same thing that the Apexi ACV-R uses.
So you need to actually purchase the solenoid separate, and then install it.
It doesnt come with the PowerFC itself
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815554
na i dont have pfc boost controller just one of those GFB ones.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815581
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
