Yeah.....................all knock-offs are the same :)
Little linishing and sanding will make it look ok.
Has anyone put them side by side with a Greddy?
And actually seen if dimensions are identical etc etc.
Otherwise it could potentially do more harm than (possible) good
  • Replies 94
Posted Images
Guest 40th-edition
I bought one off ebay, actually the same one as posted above. Unfortunately it arrived damaged, most probably through the poor packaging and will be sent back to the supplier. So far he has been good about the whole deal, so lets see what happens.
You get what you pay for. I was aware of the poor quality, as i have seen one on another car, at my mechanic's w/shop. I plan to linish and sand the outer surface to make it smoother b4 powder coating it. It should look pretty neat by the end of it.
Below are the pics i took, to right a report to the seller.
if that broke in the post i can just imagin whats going to happen when u tighten it down or get it hot..
thats going top last about a week!.... i would rather go to she shop and hold it, see the quality and have some garrinty about the usage!
but its not my money. good luck
I had a stock rb25det plunum break when my new engine was gettign deliverd. Cast manifilds dont lend them slefs to impacts.
Courier companies especially when ordering from china can be pretty rough of packages.
The autotechnica ones are the same thing with just a rebadge.
Yea dude thats really true, my mate was a courier and i went on a few runs with him and i couldn't belive the shit i saw. At their depot its like they play bowling with everyone's packages. Fragile or not its still going for 6 and when something broke it was a bonus lol, no one gave a shit there.
Yeah.....................all knock-offs are the same :laugh:
yer i got one of ebay, the casting isnt of that high quality, it did have a few little holes in the cast but ive filled these with with a tig and sanded them away, its pretty good now especially for the price i got for, if you dont mind a bit of work then get one. Mine didnt arrive in such bad condion as Al showed in the pics above so maybe i was just lucky.
Getting mine replaced, hopefully the guy is honest and comes through.
I have one of these on my car was a bit pissed off when I got it the casting was a bit rough but was all structually sound took it to the performace shop down the road they said it was the same as the greddy 1 and myte as well use it, sanded it up and put a etch primer then a high build primer on painted it black with a red pearl looks the part now.
anyway back to problems or issues, your standard throttle body will not fit as its designed for the q45 but allgud i was told my standard t/b will be good for 300kw so got a mate to make up an adapter plate for it which was allgud but quite a mission because the holes were so close to oneanother.
The plenum did not come with any nipples or bolts so had to source them which was actually soorta costly.
supprisingly my throttle cabel juuuust reached am prepared to replacve tho haha.
if you do decide to use a q45 fuse box will need relocating, but in my case i had to remove the washer bottle.
1 up is the i/c piping on that side is soooo short. one more thing was you can fit the standard fuel rail on but with the cast be aware that it may need grinding flush as it may not bolt down entirely 100% causing a vacuum leak around the injectors.
Now what every1 is wanting to hear, car went abit harder indeed my car was only on standard boost then and the response in my oponion is ALOT better, till my car has something wrong with it now haha, not anything to do with the manifold tho haha-hopefully.
It does clear up ALOT of the crap in the engine bay pipes etc and made it look alot more impressive im happy with it so far.
hey man i think while i was doing it i took some on a disposible cam so ill get them developed and take a pik with my digi cam and post them up if they are clear ill also take of pik of my e/bay now so you can see all the clutter gone.
yer well thats ok cause all problem you come up agains i have already deleated half of them asi dont have a wosher bottle and i have top feed rail and ill source the parts cheaply thanks for the heads up
yer i will be Extrude Honing the manifold to get the best result
Maybe you should look into Extrude Honing the manifold....?
How much and where?
Does the Extrude Honing make the surface really smooth, like when you port and polish? As i still want a slightly rough texture on the inside surface.
It will give a VERY smooth finish if you want. I believe you can choose a series of different finishes, depending on the medium they use.
I don't think it would make a difference inside the manifold though. The cylinder head maybe.
Klenn thank you for report.
Does it have a nipple (or a hole for a nipple) for turbo water-feed near cyl. No 6?
Where is your washer bottle now? Is it relocated or totaly removed?
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
