Hi all,
I have an RB20DET and was wiring up my AVCR to it the other day only to find out that my computer doesn’t have a RPM signal wire. The taco doesn’t work obviously and never has. So what I want to find out, is how to hook up an after market taco to the car? Any help would be appreciated.
https://www.sau.com.au/forums/topic/151119-need-help-with-taco/
mmm.. I like Taco's....
sry... I couldn't help myself... :whistling:
Is it the standard Tacho that doesn't work, or are you referring to an aftermarket Tacho that has never worked?
Edited by insanity
The RB20 is in my S13, so the standard taco hasnt been hooked up. But the actual ECU wire for RPM signal is not even there. So I am going to try to hook up an aftermarket Taco, so I need to know where the wiring would go for that, like to a wire in the igniter unit or something?
Well, if you can explain to me how to hook my standard S13 taco up I would more than prefer to use that, but I have been told many a time that this is not possible due to it being a taco for a 4 cyl.
some one is feedin u bullshit the tacho will work but will read wrong u need to put a r32 tacho in the the s13 cluster 4 it to work and read proplery
did u do the conversion or did some one do it 4 u
TACOS
The sandwich of Mexico
Ingredients
DIEGO'S & GRINGOS white corn tortillas
Chopped chicken, steak or mince, cooked with a little salt and pepper to taste, or a few teas. taco seasoning.
Finely shredded lettuce, chopped onion and chopped tomato
Grated cheese
MEXI SAUCE
Little oil for frying
Preparation
Prepare all the fillings ahead
Have a covered bowl lined with paper towels standing by (this will be your "tortilla warmer")
Use enough oil to cover bottom of fry pan. To prepare on the grill, just spread a little oil on the surface, make sure you grill is not too hot. This is a good way to do a lot at a time.
Using tongs place the tortillas one or two at a time in the pan,
Cook until limp and a light golden brown, remove, pat with paper towel and place in the tortilla warmer, keep covered.
Everything goes on the table, and everyone builds their own.
There are any number of ingredients that can be used to make the taco even more special. Try: guacamole or sliced avocado, sour cream, fresh salsa (recipe in entree section), tiny diced potatoes fried golden brown, refried, borlotti, pinto, or kidney beans all of these are frequently used.
Other Notes
TO EAT - Just take a tortilla from the warmer, fold in half and fill, don't get your tortilla too full as it will split or break on you, its not rude to have 5 or 6.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
