lol it sounds like someone going "oooo ian!" *in seductive voice"
not sure. i woulda gone for 111ANS or IAN532 if you wanted to keep it cheap. my personal favourite was XCU73 (execute) but thats taken now *bastards*
:huh:
Yeah ian, i rekon there could be better than that, if perhaps try.....
Ians 32
or lame i know but GT ARR
and of coruse 069ARR hehe
And mabey Ianses?
OMG hahah i just did the same plates and said it differently
but either way i think you should get a IAN532
Can we poll that? :P
Edited by ze_flexy_1
see, told you ian, get IAN532, steph likes it too. that way you wont be sex deprived later :huh: j/k still it would suit you, because your name is ian and you drive a 32, what more do you need?
Holy crap! totally agreed,
oh and errm yes you will be totally sex deprived if you dont do it, errm yyyeeahhh
