A while back Garret changed the naming of there turbo's to add the rear housing size into it.
My turbo is actually a GT3540r but if you were to buy one now its a GT3582r because its got a .82 rear housing on it.
Same turbo's just different rear housings so check which rear housing it has on it. the gt3540r may even have a 1.06 rear instead of a .82 so then its not a GT3582r equivalant.
if you get what i mean
Whats the difference between the Garret's GT3582R and GT3540R?
I've been looking up Garret's website and far as i can tell, they have info for GT3582R but nothing on GT3540R..
I'm not going to debate that one but from all my sources .
Garrett was having trouble with turbocharger identification because their previous handle GT3540R tells you turbine series "GT35" with compressor series "GT40" or just 40 . "R" means rolling element or ball bearings .
Where this system falls down is there may be several different major or outside diametre types of GT40 compressor which there is - 82mm and 88mm . So they changed their naming system to turbine series "GT35" and compressor outside diametre (OD) in mm ie "82" and the "R" stayed the same . So GT3582R is the current name for that turbocharger . They can and have been called GT35R/GT3540R/GT3582R , all same thing .
The system is still flawed because you can have different famillies of compressor in the same or very similar OD , this is how people confuse the real GT3076R turbos with the hateful GT30/TO4S turbos . Their compressor wheels are within 0.1mm and the trim size numbers the same . Buyers MUST find the part numbers for the turbos they want and not get "substitutions" because seemingly minor differences are not trivial . Search turbobygarrett site for the unit and cartridge (CHRA) pt no's , don't have time to find them ATM .
Cheers A .
Cheers A .
I recently bought a GT3076R (a few weeks ago) and they have a GT3037R badge on them, so even though you order under the new system it still may be badge as per the old system.
Edited by AWD2Go
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
