the easiest way is to run a vacuum line straight from a boost source (from memory factory rb25 has a nipple on the intercooler piping near the turbo) to the nipple on the wastegate actuator. Done.
Alternatively if you want to hook up the rb25 factory high/low boost solenoid system, it is a little more complex and harder to explain in writing.
Thanks for that mate, so if i do it the way you have said without using the 2 stage boost solenoid how will the boost be delivered? As in will it deliver standard boost from the beginning instead of low then high
