the 3.0L twin turbo 2JZGTE motor is possibly the best engineered inline six built to date that is affordable. It has probably the best power to capacity ratio of any of the six cylinders available today, and are also a damn reliable bit of gear.
there is also a lot of jap aftermarket support for them too (which is not necessarily a good thing considering not all the jap spank makes things go faster).
All the RB26 fans will be in here in 1/4 of a second to defend the nissan stuff, so it boils down to you researching all the options yourself and deciding what is the best for you. an RB will always be an easier conversion into a skyline for example, but last time I priced an RB26 GTR motor it was twice the price of a 2J. :)
I own a mkiv TT and a 32 GTR and I can tell you from experience that the Supra engine wins hands down. Torque from the 2JZ is enormous from 2,000rpm and pulls like a freight engine to 6,000rpm. It flats out after that. The stock RB26 doesn't pull untill well past 3,500rpm and my modded one doesn't move until after 5,500 rpm. As a daily street machine, a BPU++ Supra eats anything in its path.
Then you lose the 4wd. Believe it or not, one of the Japanese tuning house has stuck a RB26 under a Supra hood and is racing the mutant with some success.
To give credit where credit is due, its relatively easy to spin the RB26 past 9k but doing even just 8k with a Supra will be much harder because of its long stroke design. The 6 speed has also got much shorter ratios meaning that if you're racing a GTR from a rolling start, when you shift from 2nd to 3rd, the guy next to you is right smack in the power band pulling a car length or two on you before your 3rd shift is complete. That's assuming both cars have similar power of course.
out of curiosity...my mate has a supra rz engine (i think its called), standard non-turbo supra. can he or is it possible for him to put a turbo in? i mean i know its possible but he seems to think that all he has to do is get the turbo and put it in (and only spend money on the turbo and installation-a couple of grand he rekons.). i thought that u would need a 2jz engine to cater for the turbo, or different wiring and along with the other shit to get it from a non-turbo to turbo.
Apart from different ECU, wiring, and different compression ratios you also can't just bolt the turbo manifolds to the NA block but I can't remember exactly what's the technical reason. The block is also different as there are oil squirters in the turbo models to cool the underside of the pistons. The NA block don't have this feature.
Ask your friend to check out www.mkiv.com. There's loads of info on mkiv and conversions. "Easiest" (and that's a relative term) way is to put in a 2JZGTE with harness, computer and the 6 speed but the conversion cost is not cheap. Economically, it might be cheaper for your friend to sell his NA and buy a turbo. Also check out the SX Engineering's website. I think they are developing a turbo kit specifically for NA Supras. Hope that helps.
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
