I need someone to check out a 5 speed :happy: Mr30 l24eT for me in canberra.
i escpext this person to be able to drive ( as this car has angry bits)
Photos and test drive essential.
Please reply here!
EDIT:
this guy is a young mechanic and he bought it from an older guy who said the engin is an import from japan.
the head casting is a N47, which is a 84 onwards standard aussie head isnt it?
im just thingking maybe he told the young guy that or maybe it actually was modified in japan then shipped here....
so basically the question is, is there such thing?
Edited by MAG86
i'd try to get the ID off the block to confirm L24 first, if the car is an import get that info, there were NO turbo aus built factory cars offered so it would have had to have been imported or built here in oz...compliance is what you want to see....
My accountant has an R30 with L24et. It has no Aus compliance plate.
there are 2 plates involved here, the importing compliance plate that would say the car came over with such and such an engine or the Mod compliance plate to say the engine has been turbo'd and engineered to aus standards. the mod plate is a hit and miss thing though....with out it it might make it hard to register in another state...
was your accountants car factory built or workshop/backyard built?
There are factory released l24et's. Check with the nissan's listings. Quite intresting.
the car is an 1984 Aussie Ti, would of origionally had a L24e.
The ENGINE is said to be an import.
sorry for the confusion.
where do i check for nissans listings? i cant find any info at all!
the head is def. a n47
Is there much difference between a n42 and n47? there is a rebuilt n42 on ebay for $40... would it have a lower compression ratio???
thanks for the help so far!
you learn something new every day....
i've never read anything that has listed an L24et version r30, does it give a model # or was it a special release?
I've never seen anything mentioning an L24ET in any production car . I think some were screwed together for American race classes , not certain but wasn't IMSA GTU an under 2.5L capacity class ? From what I've read only the L20A and L28 had a production turbo option . Also I'm not aware of the L24E being std to anything but an MR30 .
Will look into this , cheers A .
Look in WIKI-NISSAN, go to engines.
http://en.wikipedia.org/wiki/List_of_Nissan_engines
"Straight-6
Nissan's Straight-6 engines include:
1965-1967 Nissan H engine — 3.0 L — H30 (See Straight-4 above for other H engines.)
????-???? Nissan P engine — 4.0 L — P40
1968-1983 Nissan L engine — 2.0/2.4/2.6/2.8 L — L20A, L20ET, L24, L24E, L26, L26E, L28E, L28ET (See Straight-4 above for other L engines)
1969-197? Nissan S20 engine
1980-1988 Nissan SD engine - Series Two — Diesel 3.3 L — SD33, SD33T (See Straight-4 above for other SD engines.)
1985-2002 Nissan RB engine — 2.0/2.4/2.5/2.6/2.8/3.0 L — RB20DE, RB24DET, RB25DE, RB25DET, RB26DETT, RB28DETT, RB30E, RB30ET, RB20E, RB30DE
198?-19?? Nissan RD engine — Diesel 2.8 L — RD28, RD28T"
One thing i do notice is they do list an RB24det, RB28dett, RB30de ( may be the M30 r31)??????
Edited by rsx84
"Straight-6
i looked at the same site and found noting they dont exsist
Go talk to nissan them-selfs. Dont run off or relly 100% on internet information. According to City Nissan parts department here in wellington, They have a listing for a factory l24et.
This car has only the factory plate and no evidence of any other plate being fitted,
There were plenty of R30 with turbo motors, but nowhere can I find any evidence of an L24et. There was an L24S. And there were cars shipped to NZ that were hybrids They were not available in Aus. because of the "Supercar" controversy. And may have been specials, such as Autech etc.
I'll keep looking.
Not anywhere I can find.
The first EFI L24 surfaced in what we know as a C211 in 80/81
My sources tell me in Japan's R30's the only engines were; Z18, L20B, FJ20E, L20E and L20ET and later in the DR RSX came the FJ20ET & DET. It is my understanding the only L24E's went to Australia as Skylines and USA as Maxima's. The M30 Infinity using a VG30E engine. A diesel LD28 version was produced for South Africa & Middle East.
But alas, as SteveL says, No L24ET! No such potato ex anywhere Nissan.
Somebody is havin a loan of you
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
