  • Replies 103
Hey Dan,
DJ Albert and myself were at Villawood Maccas and no one showed up...
we saw u drive back up woodville road and we thought u were going to Merrylands maccas. we went to merrylands also and no one was there so we went back down to villawood and no one was there....
pretty disappointing.....it was hot but at least if more ppl showerd up we could have gone to the beach....
hope u didn't go too much out of your way with the food....
Sorry it turned out like this....
next time..
- Bam
Hey Dan,
next time..
- Bam
yeah
guys I was waiting around forever and just one person turned up... :happy: skylinegtts
I thought no one was coming so I just went home.
Very dissapointing no one turned up and once again money spent on food...
Sorry to anyone that did come after I left...
I was there until 9.35am
Sorry that people didn't bother to show up. Hope you didn't go too far out of your way with food?? Maybe you can save some for the freezer or something.
All of us from Nowra were ready to go (I even didn't go out drinking last night because I knew I had to get up today), and I'm sure those coming from Canberra were too. At least you know that if there is a next time all of us from down South will be showing up.
I think that being in the morning can be a drag but this time was based on distance and time - would have got here by around 1 or so I rekon so that would have been the right time for BBQ. I know if us down here want to come on a Sunday cruise to go out to the Blue Mountains etc we have to be out the door by around 7am to meet up with you in Sydney by 9:30am. Kind of a compromise thing. And no I'm not having a go at anyone so don't take it the wrong way.
Thanks for putting in the effort to organise us - I know its not an easy thing especially when the weather gets in the way. Hope that maybe you can still make it down sometime when its a bit nicer. I'm sure we would all be keen to just meet up in Wollongong or something next time...
Have a good one, and thanks again :P
wow...
Very disappointing that people didn't show when they said they would.
sux that you were put out buying meat etc...
at least now you can have a monster barbie @ home :)
dan, you should come on the wisemans cruise, it's not organised by you, so no headaches :stupid:
yeah... cant believe no one showed up... we did get unlucky with the weather though
you guys should have caught up to us... we were waiting there for nearly an hour and no one turned up
Like I said man, I had a legit reason not to be there and am happy to pay my share for food as I had previously told you I would be there.
Thats all good Adam, just for the record Adam offered to pay his share via PM...
I appreciate your generousity but its all good... ;)
Mate your a very genuine person!
I look forward to organising another cruise in the up coming month or so! :P
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
