  • Replies 103
Hey Dan,
DJ Albert and myself were at Villawood Maccas and no one showed up...
we saw u drive back up woodville road and we thought u were going to Merrylands maccas. we went to merrylands also and no one was there so we went back down to villawood and no one was there....
pretty disappointing.....it was hot but at least if more ppl showerd up we could have gone to the beach....
hope u didn't go too much out of your way with the food....
Sorry it turned out like this....
next time..
- Bam
Hey Dan,
next time..
- Bam
yeah
guys I was waiting around forever and just one person turned up... :happy: skylinegtts
I thought no one was coming so I just went home.
Very dissapointing no one turned up and once again money spent on food...
Sorry to anyone that did come after I left...
I was there until 9.35am
Sorry that people didn't bother to show up. Hope you didn't go too far out of your way with food?? Maybe you can save some for the freezer or something.
All of us from Nowra were ready to go (I even didn't go out drinking last night because I knew I had to get up today), and I'm sure those coming from Canberra were too. At least you know that if there is a next time all of us from down South will be showing up.
I think that being in the morning can be a drag but this time was based on distance and time - would have got here by around 1 or so I rekon so that would have been the right time for BBQ. I know if us down here want to come on a Sunday cruise to go out to the Blue Mountains etc we have to be out the door by around 7am to meet up with you in Sydney by 9:30am. Kind of a compromise thing. And no I'm not having a go at anyone so don't take it the wrong way.
Thanks for putting in the effort to organise us - I know its not an easy thing especially when the weather gets in the way. Hope that maybe you can still make it down sometime when its a bit nicer. I'm sure we would all be keen to just meet up in Wollongong or something next time...
Have a good one, and thanks again :P
wow...
Very disappointing that people didn't show when they said they would.
sux that you were put out buying meat etc...
at least now you can have a monster barbie @ home :)
dan, you should come on the wisemans cruise, it's not organised by you, so no headaches :stupid:
yeah... cant believe no one showed up... we did get unlucky with the weather though
you guys should have caught up to us... we were waiting there for nearly an hour and no one turned up
Like I said man, I had a legit reason not to be there and am happy to pay my share for food as I had previously told you I would be there.
Thats all good Adam, just for the record Adam offered to pay his share via PM...
I appreciate your generousity but its all good... ;)
Mate your a very genuine person!
I look forward to organising another cruise in the up coming month or so! :P
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
