I have been needing a solution for my AFR's for a while now and while I could get something like a SAFC I have figured I might as well spend a bit more and get something a bit more comprehensive. The control over timing and the removal of other ECU limits will be useful. Was looking at the Power FC's but now as their not readily available I have been looking at the GReddy E-Manage.
I just wanted to know, is it work getting the Ultimate version? What are the useful extra features over the Basic model? The thing is for me, besides the extra cost of the Ultimate, the Basic version can also be interfaced to the E-01 boost controller screen which might be useful to me if I get one down the track (if I can find a good location for the huge thing in the cabin :huh:)
Any advice would be greatly appreciated :P
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/
  • Replies 43
how exactly does the emanage remove ecu limiters ?
I think its just limiting the sensor readings before they hit the ecu limit , which isnt as useful
you can still get pfc's new for rb25s , there a little more expensive than they used to be but not by much and still good value
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-2814593
Car is a manual.
Yep I aware I could still get a PFC if I tried and I know it would be the better solution, but ultimately as I was originally just looking at getting an SAFC I think the E-Manage is the better option. With the prices of PFC's now for an R34 plus tuning I would be looking at a total of around 2k.
Also I have looked further into the differences between the Ultimate and the Blue version - I think it will be worth getting the Ultimate and missing our of the Profec E-01 compatability.
Now what do people think tuning costs might be for the E-Manage? I am assuming it will be less than a full tune with a PFC as really only the fuel and timing maps will need to done - is this correct?
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-2814900
Car is a manual.
Thanks :no:
Is the Ultimate a full ecu replacement? I cant remember I think it is. While the blue one is a piggyback.. The PFC takes no time to install...thats where your cost will be..and asusming ur tuner has the software for the tune, which he should.
I had an emanage installed and a PFC...the emanage cost me more (blue basic one) as it took longer to install..tuned fine though.
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-2820591
The Ultimate is still a piggyback ECU, just a very comprehensive one. I'm thinking I might give the actual installation a go as I am pretty handy with that kind of thing, and it looks pretty straightforward as long as you take you time and make sure you have it all done right before you power it all up. Then tuning shouldn't cost as much as a PFC tune (I don't think).
I don't know maybe I will wait a while and see what happens in regards to a new model PFC, or maybe I will come across a second had one cheaply (doubt that though).
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-2821192
its the splicing of the wires that takes the time on the piggyback. Ive done it with a SAFC, cbf doing it again.
the PFC fits straight into the stock loom.
Tuning will be roughly the same, its all about time. If they are not used ot it it may take longer.
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-2821342
  • 2 months later...
Car is a manual.
Tuning an emanage is quicker than say a powerfc so dyno time is reduced, but if the tuner is inexperienced with emanage then you will probaly pay the same. So there is an advantage to go to some-one with emenage experience if you want to save $$$
The software is set up so that even a green tuner can come to grips with it very quickly. The instructions for use are fairly average so we lucky it is pretty much self explanatory :D
dont get me wrong i still tune as many PFC's as emanage but i find many have "overspent" and could have got the same result with less expense. for guys happy to stop with mild mods the blue emanage is fine but if for any chance you do decide to continue on the mod path its is fairly easy to "outgrow" the blue, whereas the ceiling for mods on the ultimate is pretty much the same as a PFC.
Edited by URAS
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-3008881
all I know about emanage is 4 years ago walking past the greddy stand at tokyo autosalon a japanese guy turns to his japanese friend and says "emanage?" his friend replies "fck off emanage!!" it's had me (and nick) in stitches ever since.
other than that they look good for the price and are definately a little cheaper than the PFC and have some nice options too (like 2 maps, ign cut etc). but they certainly wont be any cheaper to tune than a PFC. will be about the same I would think time and cost wise over all.
if I don't sell the GTST soon I may try one on it since atm the only easy options for them are modified GTR PFC, or scarce AP engineerng PFC, or chip and tune the stock ecu.
https://www.sau.com.au/forums/topic/151247-greddy-e-manage/#findComment-3008882
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
