hi there
still hunting around for towbars, considering the max ones, but would need to get it fitted in SA.
I also went into a reputable tow bar workshop today. Quoted 495 for a custom heavy duty tow bar fitted... BUT they cannot fit H/D to my car as it was a large fuel tank and cant run tow bar stuff to one side of the chassis rails for strength/integrity. the could do the basic one for $395fitted which i dont want as i cant tow a car with that!
So - if i was to get a max towbar, and took it somewhere in SA - would they say 'we cant fit this and dont recommend etc etc etc...
Who has got a h/duty towbar in SA and where did you go???
thanks
-Matt
https://www.sau.com.au/forums/topic/151255-towbars/
Tried to fit it myself but slight grinding and drilling required. Did not have tools at the time so got it fitted somewhere else.
Overall, nothing major and if i had had a grinder/right tools at the time, I could have done it.
Afterall, we are all but mere mortals.
https://www.sau.com.au/forums/topic/151255-towbars/#findComment-2821820
I had my Max towbar installed by a workshop in sydney. Design of the towbar is great and nice and strong
Fitting was a real PITA, my car has a rear spoiler extension which made it much harder and the measurements were not quite right so some adjustments required. Also needed to modify exhaust mounts to ensure the muffler didn't hit.
But the bar itself seems to be the goods, I need to tow heavy cars so I needed it as strong as possible
https://www.sau.com.au/forums/topic/151255-towbars/#findComment-2828561
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
