HI All
so i got my new splitfires today, put them in, ran 1.0mm gap, and getting missfire at the usual rpm 4500-6000. Only running 10psi of boost, had no problems wiht old coils at 0.55-0.6mm at the same boost,
SO WHAT THE HELL. The reason i got these is to stop the missfire and increase my gap to increas mid range pull and fuel ecconomy, so gapping down is a bit of a waste of my money.
Is it possible that the earth might be a bit crap or something?
CAN somone advise me ASAP please
Edited by WogsRus
  • Replies 92
It's a series 2 with no ignitor. In regards to bigger problems, what else can it be, could the problem be a CAS sensor or something else.
I am going to regap to 0.8 but this sux, hopefully i can sorgth it out.
I have no errors on the computer, it has been tuned, new pump and so forth, the car did not miss at 0.55 gap, but the coils were shot, i mean i could hardly see the spark.
Sorry should have explained. When i got the car stock it was ok, but soon after i saw some cracks in the coils so i silliconed them up and they ran for a bit and then got worse. SO i gapped the plugs down till they worked wich was 0.55mm.
I am running the copper plugs that everyone gets on here, the BPRS6 things, NGK, you know the ones.
My fuel ecconomy started to suffer as soon as the coild started to fail, so i am trying to fix this by trying biger and better coils with bigger gap.
Thats not the right plug code... you sure thats it?
There are a few that are similar.
If you gap them down and its working, you have a faulty connection somewhere and isnt letting the power through
Find the cyclinder thats misfiring and it will be easier
Well series two with ignitor, did check with MM, and primary is 1.4k ohms, wich is standard for series two, series ones are like .6k ohms.
AFM is clean did that, just finishing the plugs and see how it goes.
BTW i am on my lappy next to the car while working so hence the responces on the run.
OK so
gapped to 0.8mm, still get a slight miss under 3 full load, bugga. I guess there must be something else wrong, not sure what though.
Any ideas. If my engine was getting crappy earth, would that cause problems?
ALSO installed an R32 wastgate actuator, and DAm, doe the car pull much better now.
HOWEVER also noticed with the splitfires, the car idles better, more pull through the midrange (this was before the actuator), and easier starts.
SO all i need to do now i figure out why it might still be missfiring.
I read somwhere that if the CAS is playing up that might cause some issues.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
